the mast itself can be raked but what ever you do, it has to be straight. If there is the slightest bend, The middle of the furler with mainsail furled in will jam in the middle of any mast where the bend is(a lot here is tuning).
I urge all to check with the Designer of YOUR boat.
Straight from MY boat's Hunter manual.
"The amount of BEND desired depends on the way the sails are cut. As a general rule, however, a calculations based on .07 of the height of the masts above the boom can be used to determine the normal mast BEND."
This is for Hunter's B&R rig on a boat in 7-8 years in production. Mine was mid range of those years, 1997.
My in-mast furling now WORKS with a bend of about 9" and a 59' mast by Z-Spars.
I am not posting this to argue, but for all to consider the many aspects of in-mast furling.
Think about YOUR boat and research YOUR boat, as I had to do.
With my ≈60 feet and ≈9" bend is nothing in a hollow mast with ≈6 " of frees space inside, where 9" in a say 30 foot mast is a lot. With MY furled sail, there is still about 2" of free space between the wrapped sail and inside of mast.
One reason for pre-bend is to prevent mast moving in high winds and fatiguing the aluminum over time.
When the sail is unfurled and in a beam reach, the inside furling tube (foil) is bent and conforms to the mast BEND. When no/slight wind in the sail, the foil straightens and is free to turn in side MY mast.
Even if there is drag or friction of sail inside the mast, what does that have to do with a Jamb in the Slot?
( ouch my back hurts from more resistance to sail furling/unfurling)
Note Ralph's pictures of mast cross section with furled sail in side HIS mast, in post#8, picture #2.
Jim...
PS: Z-Spars still makes in-mast furling and if YOU have their mast, check their web site for more info on "how to's" for furling.
