Wife got me a smart plug
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
Has anyone else done this replacement. Anything I need to watch out for? It looks pretty straight forward.
Aug 24, 2009
444
Catalina 310 Sturgeon Bay, WI
Check out the recent Fall Issue, Vol 33 No 3 Of the Mainsheet (page 19)
There have also been a number of people on this board that have made the upgrade.
Hope it helps...
Russ
s/v Long Story
Aug 2, 2009
651
Catalina 315 Muskegon
I put one on my '96 Catalina 28 a couple months ago. I already had a fairly new shorepower cord, so I opted for the kit with the adapter for an existing cord. Attaching to the cord was easy enough, and attaching the receptacle to my boat was easy, too.
I'll take MaineSail's word that it gives a better and safer electrical contact. I also find that it's easy to plug in and unplug in use. And very secure. Glad I did it.
Aug 26, 2007
284
Hunter 41DS Ventura, California
I converted my 41DS about a year ago. I bought the cord/ boat receptacle set and an additional cord plug to convert my old cord for a spare. Both easy installations and I don't worry about plug shorts/ fires anymore. Pricey but worth it- great product!
Clydo
May 28, 2013
371
Catalina C310 SF Bay/Delta
Did this procedure last year. Easy to install plug on shore power cord and pretty easy to
install box on stern. Great safety feature and easier to plug cord in. No need to find proper
slots for prongs. Straight in and out.
Clyde Thorington
C310 # 245
ILEAN TOO
San Jose, CA
Aug 24, 2009
444
And - if you have an inverter be sure the 12 volt power back to it is also turned off. A lot of people don't know that when you have your inverter turned on you are back feeding your 110v input and finding out can be shocking,.... :yikes:
11,772
On a properly wired vessel back feeding shore AC should NEVER happen. If improperly wired then anything is possible..
May 21, 2013
45
Hunter 410 Stuart
Hi,
I'm thinking of converting to the Smart Plug system too. I only worry, whether my old "sockets" are of the same size, screw positions etc., as the new ones for the Smart Plug. Is this a standard socket and thus a hassle free and simple bolt-on solution, or will I have the chance to run in to cutting drilling and fiddling new cut outs?
My boat is a 1999 Hunter 410 and here is the pic of the actual sockets:
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Hi,
look in the archives for pics of others who have done the change out and that will give you a visual of how the finished product looks
Clydo
May 28, 2013
371
Hi,
As I recall (dangerous) think everything fit ok without drilling new holes, etc.
Clyde Thorington
C310 # 245
ILEAN TOO
San Jose, CA
Sep 29, 2008
1,981
Update: Was simple to replace the socket as all the holes lined up and were the same size (it was designed that way). Equally simple was the plug replacement; only hard thing is sliding the cord through the strain relief (use lots of wet soap).
