Help buying my first larger sailboat
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
If I lived in Washington and wanted a cruising boat, max for the money, I'd seriously consider having a look at this one--an Irwin 41 CC w/ recent up grades. As others have said, go large if you can. One "trial" option in my opinion is to go to Cooper Boats in Vancouver, charter w/knowledgable friends for 7 days a boat around 40 ft., then sail to Naniamo, down the Gulf Islands to Salt Spring Island (Ganges Harbor) then back to Vancouver exiting through Porlier Pass and across the Georges Strait, visiting the various anchorages along that route. After planning, and doing, that I guarantee you'll know what you want to do!!
http://www.yachtworld.com/boats/198...4519/Gig-Harbor/WA/United-States#.Ve-0W9JdW-g
Jun 1, 2015
6
Catalina 27 Bradenton
I'd look at ASA or one similar, and it will give you an opportunity to try various boats.
Seems your concerns as others pointed out is cabin height and area of coverage. I'd look at something with moderate work but ready to go out on. As you'll learn what you want, amenities, and how you want it rigged work wise. Everyone has different feelings about central located rigging to the cockpit being useful yet taking away from being familiar with working around the boat up forward. Or time length of your planned cruises. Thats why I suggest ASA so you'll have that advantage to go out while shopping for what works for you.
Good luck and happy cruising.
dhays
Aug 2, 2010
93
Catalina C400 Gig Harbor, WA
I live in the South Sound and have sailed much of the Salish Sea. FWIW, here are my thoughts.
Draft: If I see a depth of 20 feet I get nervous. My C36 had a depth of about 6', my C400 has a depth of about 7.5. There has never been a place I wanted to go that I couldn't other than the swinomish channel, but they dredged that again a few years ago so I am going to go there soon.
I would strongly suggest that you stay between the 27-36 foot range. Get much above that and moorage costs rise a lot and it is simple a huge jump in learning curve. My 36 still handled and sailed like a dinghy, my 40 foot not so much.
Stu is right about berth size. I am 6'2" and my wife is 5'10. We found the aft cabin in the 36 to be too cramped for us but the forpeak was acceptable. Get something with enough sleeping room for you.
If you don't mind rehabbing old homes then don't be shy of rehabbing old boats. However, a good survey will tell you what the problems are, then check out on the forums to find out how much work and expense it will take to resolve those problems.
Get a boat that performs well. When the weather is warm, there is little wind here. You want a boat that will sail well under those conditions. When the wind picks up, that is when you reef.
There are a lot of older boats that would be well within your budget. While I think the Catalina 36 is one of the best production boats ever designed with probably the most sold and the most supportive and helpful owner base, I would suggest looking for an older Catalina 34. Great boats, sail well, and as Stu mentioned a nice forepeak. Both of those boats are plentiful and affordable for you. Good luck.
Dave
68
Cal 33 ft. MKII Clayton, N.Y. St. Lawrence Rvr
First of all, let me say it took me 2 days to read all of the replies. OUTSTANDING! Now you must go out and choose. I started sailing in an O'Day daysailer 16 foot. I then proceeded upwards boat by boat using approximate waterline length as my guide. My O'Day led to a Pearson Ensign w/@16ft waterline, then to a Catalina 27 @21ft WL and now a Cal 33-2 @27ft WL. I have thoroughly enjoyed the journey. I take exception to the very first comment: "Capta" #2, in that I have some homebuilding skills and especially that I was a jet engine mechanic on the USMC HARRIER. Point being, I have taken those skills and easily maintained and modified all of my boats when and where necessary. Especially in the "engine" department. A jet engine mechanic makes a qualified diesel mechanic. If you have the skills and if you feel up to the challenge of a bigger boat, absolutely go for it. Sail all that you are interested in before you choose just one. Do the research and ask more questions here in the forum. You will be just fine.
Sep 12, 2015
3
Monark 606 Vänersborg
Flatlander,
What's the basis for your preference of a fractional rig?
First of all:
Where is Dailytrek? Isn't a dialogue better than a monologue?
Fractional rig:
How typical will tacking and beating be for Dailytreck?
On an open sea MH will be the best rig but if you have islands and even worse an archipelago like we have in Sweden (where I live) and Finland a fractional rig is better. Tacking and beating with a small jib is very much better than with a max. genua.
Budget:
If we have a total budget of $50 000 at least $15 000 should be reserved for a new motor.
Most likely the boat for this budget will be older than 1985.
Aug 25, 2015
30
San Juan 28 Sequim, WA
Tacking and beating?
Sorry for the absence...I've been digesting all the information I received from the posts here and looking at boats...and three days at the Wooden Boat Fest in Port Townsend. Most of our sailing will be in the straits of Juan De Fuca into the wind and running, as well as the numerous bays along our coast as well as Pugent Sound and the San Juan Islands.
First of all:
Fractional rig:
Budget:
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
If you're ever in Anacortes, id be glad to show ya my S2 36. You mentioned a budget of 50k max..you need to find an older boat that needs updating and do the work yourself. And when you find such..keep in mind the standing rig will probably need replacing and condition of sails and condition of engine and condition of running and do you need heat and do u need an upgraded alternator and well, you know where were going. The S2 has 6'3" from companionway to v-berth however it is not a full keel but it is a very responsive boat. The boat has a very good reputation. In the waters you state, im not sure a full keel would be mandated and same as fractional rig. We bought ours 4 yrs ago ( my second one) and have been using it every summer and then use the winters for major projects like new tanks or rebuilding the engine. I have to do all this work myself. $100/hr just adds up to fast and i then know what i have. This will probably be the last winter and well keep it sailing during the winter. So once you buy"the boat",be prepared for things like leaky tanks. Or OMG, the swages on the shrouds are cracking..etc. i now have our boat up to snuff and have spent about what the boat cost doing it so i would not sell it for 55k. The other side is to find a boat like mine ,condition wise, and pay the price which may slightly exceed ur max price. There is a Spencer 42 for sale in Tacoma. It is a full keel boat that did well in the local race circuits. My only connection is that it was my grandfathers boat (Im 62) and its the boat i learned to sail with. But its supposed to be in good shape. Hope this helps
Sep 12, 2015
3
Portsmouth Yardstick
If you go for a fast sailing boat a yardstick of 80 and lower is possible. Fractional rig is not the only alternative. You have many C&C boats like 33, 34, 35 and 36 feet for sale.
Sep 20, 2014
1,330
Rob Legg RL24 Chain O'Lakes
But if effectively, he is single handing, a fractional rig is less likely to be over powered. Spilling a single sail in a serious gust is easier than have to spill both sails.
Aug 25, 2015
30
I've been pursuing many of the ideas and am reading "20 Affordable Sailboats" per your suggestion. I've also been looking at prospective boat's Portsmouth Yardstick....as you're right, performance is important to me for the exhilaration and efficiency. I like classic looking boats for their brass portholes, wooden adornments and interesting hull lines...and plenty of real wood in the cabin....but also like the modern lines with sharp bows. I believe the full keel would not make so much sense for me at this time. Several of you along with the prior mentioned book suggest the C & C which I hope to view one soon.
I'm retired since 50 and now 61, just finished up a restoration on a gothic farmhouse (1861) and willing to work on my own boat for $100/hr....but want to sail more than work on the boat.
I could use some help understanding what to look for in the electronics....not sure what would be out of date. We get plenty of fog here in WA so I imagine radar would be nice along with the GPS, depth, speed, chart plotter, VHF. Your suggestions would be appreciated.
Also, what are the preferred stove fuels? Is a frig preferred or an energy hog?
How can I view prices of boats sold?...is this available only for brokers? I have not met a broker yet who I really clicked with around here.
Thanks,
Christian
Sep 20, 2014
1,330
Sailing Texas will give prices of boats sold and what year. Other than that completed listings on eBay.
Jul 27, 2011
5,203
Boat Buying: It's more art than science; more empirical than theoretical. One doesn't really know what a boat can be had for until putting an offer down on the table, like everything else. Brokers don't really want to discuss hypothetical. They're in the business to sell boats, not discuss them (for long). I was in the market essentially 10 yr before buying the boat I have now (but I had another one to keep me busy at the time.) I was three yr in the market b/f buying that one! CHARTER, as I said prior, if you want to sharpen your "search image." Forget about trying to "price it out." It costs what it costs, and there ain't no gettin' around that!:)
jzuk
Mar 14, 2014
13
Oday 35 Penetanguishene, Ontario
Depth and knot metre have not changed much.
New VHF's have DSC; read up on them, great addition for safety. I plan on getting one with the built in GPS, hoping I can tie that into my 'Autohelm' auto helm.
I dumped my ancient Loran system that came with the boat and plan to get an IPad (one that could have a cell card in it, they have a GPS) and load up the Navonics app. Got it on my phone now and it's great, specially for a night time dingy ride (where's the boat?).
Aug 25, 2015
30
I found the Portsmouth Yardstick very helpful on the US Sailing site but now it requires a password for membership. Can you direct me to a page where I can access this information?
Sep 12, 2015
3
Interesting data!
What does a negative value mean?
A. The boat is sailing faster than the speed of wind (not normal for keel boats)
B. The rig is so high that the boat is exposed for a higher wind speed than most other boats
Sep 20, 2014
1,330
The scale is based on a reference standard of a specific racing boat. I forget what the boat is. Negative numbers are faster than that specific boat.
Pearson 26W Marblehead
buying a larger sailboat
Im a New England sailor and not familiar with your area. I do have over 50 years sailing experience. My comments 1. Do not buy a sailboat that is built to sell for a low price. 2. look for a boat from a well thought of builder. A few examples are Pearson, Bristol, C&C, Tartan.
and finally, I would stay away from those heavy long keel types. example In the 70`s and 80`s the Westsail 32 was very popular boat. You don`t see to many of them any more. The obvious reason: They are very slow. I could go on with a lot more comments, but I will leave it at that Good luck!
