Re: Poop system alternatives
Oh dear, Diana...we need to talk!
I have it from Ms Hall that the best (and only) thing to put into the holding tank is nitrate, which effectively turns it all into dried dog poop on the lawn, which doesn't stink because it's dried-out in the air.
I have never said that nitrates are the "best and only" thing to put in holding tanks. My own company introduced the tank product that's now Raritan K.O., which is a live aerobic bacteria product...and then there's aeration, can elliminate the need for ANY product in the tank. I've recommended all of them.
And you don't have this quite right either:
I provided them (vent lines) with rigid PVC tubes to the top corners of the tank, one on each side. The PVC prevents them from sagging, which would create a low spot that will collect water and sludge and therefore stink. Ms Hall says sailboats can benefit from this most of all because the wind is usually to one side of you-- thus blowing into the vent on that side, through the tank and off to leeward where you couldn't smell it if it stunk.
Not even close to anything I've ever said, Diana...<sigh>.... The purpose of double venting is NOT to push odor out the lee side of the boat, it's to improve the supply of oxygen to the tank to prevent any odor from occurring. And the wind isn't coming from the side of most sailboats when they're underway or on a mooring or an anchor...not only sailboats but ALL boats have their HEADS into the wind...which is why I love running the tank vent forward to thru-hull near the bow whenever possible.
But this is the worst of all:
I am plumbing my toilet with a line from the freshwater tank, through a one-way valve, up to the loop and down to a valve that lets it into the seawater-flush line. By opening this valve and shutting off the seacock I can use my (copious) freshwater supply for the head. Best of all I can still flush the toilet when the boat is out of the water-- which is a great benefit to liveaboards!
Don't even THINK of doing that! NO toilet designed to use sea water should ever be connected to the onboard fresh water system because it cannot be done without risk of contaminating the fresh water supply with e-coli, damage to the toilet or both...and EVERY toilet mfr warns against it in all toilet installation instructions. Your plumbing plan does nothing to prevent the migration of bacteria from the toilet bowl into the fresh water supply.
I don't get Peggy Hall's idea of stopping up the sink when the seawater line is open.
A plug in the sink may be needed to prevent the toilet from pulling in air through the sink that prevents the pump from priming.
I'm not trying to beat you up, Diana...but I can't let bad advice attributed to me pass without correcting it. I'll be glad to help you set a system that, with minimal maintenance, will be trouble and odor free.
