Don! What is wrong with your pop top?
Coolest thing ever how? ....
Now want a roller! Yay! Boat bucks!
Exactly.I would personally use 15' for a 22' boat. In the sea I would go for over 15'! These guys don't seem to understand: its the chain that makes the anchor set! (Along with a good Skipper) Chief
Exactly.West Marine has a chart but it is all just an educated guess after all. Chief
I have mentioned this on other forums/posts.I'm sure that CD works great on the bow. I decided to mount the anchor on the side after considering that when I anchored directly after sailing, my hanked-on jib would be in a heap at the bow. With the anchor and lines on the side, I can get to the anchor easily and keep clear of the jib and jib sheets. So far, I'm happy with the decision.
Jeff, When I had my Mac25 I used to stand in the front hatch, on the V-berth. I had a box on the V-berth that I would drop the rode and chain into as I pulled it up. This worked well in rough seas. It felt very secure. BTW I used 18' of 5/16 chain. You can get away with 1/4" but that was what came with the boat.I have mentioned this on other forums/posts.
I LOVE having my danforth hanging from these kind of holders on my aft stantions. I run the rode back from the bow, so when I am soloing (which is a lot) I can drop anchor from the cockpit.
My issue with smaller boats and soloing with a roller (and I may still still get one) is how to bring the anchor chain in from the cockpit without dinging up the gelcoat. If I had a form of mechanical assistance and a locker on the bow, it would be a no brainer.
Jeff
The photo was taken the second night of the C-22 North Gulf Coast Cruise at the Palafox Marina in Pensacola. The CD C-22 anchor roller is basically designed for the Danforth #8 anchor. It allows you to pull the anchor up and stow it right in the mount. I did drill a hole for the pin to route through the anchor shank to hold it secure while sailing or driving down the road to the next destination.Don! What is wrong with your pop top?
Uhm...I want my wife to WANT to be in that berth...Jeff, When I had my Mac25 I used to stand in the front hatch, on the V-berth. I had a box on the V-berth that I would drop the rode and chain into as I pulled it up. This worked well in rough seas. It felt very secure. BTW I used 18' of 5/16 chain. You can get away with 1/4" but that was what came with the boat. PS: The anchor roller was one of the first mods to my Cat 27. Much easier on the back.
Jeff,I LOVE having my danforth hanging from these kind of holders on my aft stantions. I run the rode back from the bow, so when I am soloing (which is a lot) I can drop anchor from the cockpit.
Why would you want your wife in Frank's V-berth ?Uhm...I want my wife to WANT to be in that berth...
Jeff
Don't ask, don't tell!Why would you want your wife in Frank's V-berth ?![]()
Which windlass do you have ?Notsure if I can make the windlass work with my C-22 or not, buy by golly I'm sure gonna try.
Slim: My buddy did just what you suggest. He put his chain in clear tubing. It was a disaster, as it rusted like crazy in that semi-closed environment! The best concept I know of is to put the chain in a bag just below the anchor and hangers and tie it to the rail also if you like. I used this in both fresh and salt for 17 years and worked great! Realize that the immediate reward is you can deploy your anchor quickly. A bicycle innertube will not cut it as you will need a minimum of about 12' of chain. I would personally use 15' for a 22' boat. In the sea I would go for over 15'! These guys don't seem to understand: its the chain that makes the anchor set! (Along with a good Skipper) Chief
If it does not come with one pre-drilled, I would not do so.Okay, I've purchased a roller and I'm in the process of mounting/bedding it! For you guys who already have one, how do you secure the anchor in it?? Do I need to drill a hole in the shank?
