Not always. If the hull is planing long before it reaches that theoretical number, than the number doesn't exist. My boat seems to do that. There really is no bow wave to climb over before it planes. It just goes faster and faster with more wind. I think your skows will do that as well.I see what you're saying I'm thinking displacement hull when you say hull speed, when even a planning hull has a hull speed, buy can exceed that with the right conditions.
And where you point the rudder! I'm surprised no one has talked about the rudder. You know, the board thingy that hangs out the back and turns opposite from where you want to go. Explain THAT!...It is the NET balance of force above and below that determine where and how fast the boat will go....
that one's pretty easy, actually. the rudder is a foil. when going straight, it has the same basic lift qualities as the keel. however, turn the ridder and it acts as the flaps on an airplane wing. you push the tiller to port, the rudder angles to starboard. this places the rudder's foil at a greater angle to the flow of water, creating lift and pulling the stern through the turn.And where you point the rudder! I'm surprised no one has talked about the rudder. You know, the board thingy that hangs out the back and turns opposite from where you want to go. Explain THAT!
Right. Because sailboats are not fast.by the way, it is right to say the theoretical hull speed, as was said above. it is certainly no fast rule.
despite the jesting nature of your post: also not true. don't forget there are 60 mph sailboats, now.Right. Because sailboats are not fast.
You mean this one? https://m.youtube.com/watch?v=sZVIj5TUSKEdespite the jesting nature of your post: also not true. don't forget there are 60 mph sailboats, now.
are we talking full keel fin keel. displacement running riggingOK, so its going to be another month before the boat is in the water, so my mind is just sitting idle. So I got to thinking about what forces actually push the boat forward.
Is the forward force from the keel, or from the sail? When considering the sail shape and the lift, it seems like most of the forces are sideways, and almost no force that pushes forward.
On the other hand, if you push the boat sideways, if the keel is angled slightly leeward, the boat will move forward, do to the angle of the keel in the water. Does any side load against the keel push the boat forward?
Does the keel ever have more forward force than the sails do?
Rudders are (or should be) foils. Just like keels. On our 367 the rudders generates HUGE lift. But you have to keep the AOA (angle of attack) very small. That's why we balance the boat with the trim of the mainsail and keep the angle of the rudder less than 5 degrees unless we are turning the boat. Turn too far, and the foil stalls. That kills steerage and boatspeed.And where you point the rudder! I'm surprised no one has talked about the rudder. You know, the board thingy that hangs out the back and turns opposite from where you want to go. Explain THAT!
i don't believe that makes a difference to the question at hand.are we talking full keel fin keel. displacement running rigging
When it enters that mode, any boat that 'foils' is not longer a boat in the traditional sense.that's one. there are others, too.
i quite agree. but, that's just my personal opinion.When it enters that mode, any boat that 'foils' is not longer a boat in the traditional sense.
there is always a forward component. lift is perpendicular to the cord but, sails aren't usually sheeted in so far that the lift is only sideways as compared to the direction of the boat. sail lift is leeward and forward. keel lift is windward and forward. thus, the whole thing works to move the boat forward.Any foil that operates at an (small) angle of attack generates a force that is probably not perpendicular to the cord line of the foil. Generally when operating at small angles of attack the force has a forward (into the flow of the fluid) component soooooo
your keel is actually helping to push the boat along.
Bill,Any foil that operates at an (small) angle of attack generates a force that is probably not perpendicular to the cord line of the foil. Generally when operating at small angles of attack the force has a forward (into the flow of the fluid) component soooooo
posts number 10 and 61Wouldn't it help to clarify this thread if a simple drawing of the force vectors were posted? Anybody willing?
Gudenuph
