Mainsail's Universal Diesel amp meter bypass
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
Updated 3/28 - charging problem
For electrical experts.... I'm doing this mod today: http://www.pbase.com/mainecruising/universal_wiring_harness_upgrade I'm wondering if I jump the alt as described but leave the orange wire connected, will the amp meter still register, yet without the big charging load going through the old circuit. Also, seems that this mod would decrease the load on the alt(?)
1. You'd best ask Maine Sail directly.
2. Why would you do the mod and not do everything he suggests?
3. Here's the WHY about the original wiring: OEM 1-2-B Switch Wiring History http://c34.org/bbs/index.php/topic,4949.msg30101.html#msg30101
Assuming you have the stock setup, and are moving the AO to the house bank, if you truly understand the logic about the wiring, the orange wire between the starter/solenoid and the alternator makes sense in the old scheme, but not the new one, if you are switching (pi!) between a charge 1-2-B switch and a use switch.
Oct 1, 2011
172
Canadian Sailcraft 36T PCYC Toronto
No the ammeter won't work, I believe the red and orange are in series to,and from the ammeter, and that's the problem, that type of meter does not use ashunt and is rated for the expected loads, but the wiring isn't.
If this is what you're doing (the quick fix), then it's explained pretty clearly.
Bypass The Orange/Red Circuit
Here's the quick and dirty fix. Try to focus on the red wire between the back of the alternator and the starter post. Simply jump the alternator output to the starter post and disconnect the orange wire. With this jumper the alternator output bypasses the 20+/- feet of teeny tiny 10GA wire and uses the large gauge starter wire to make its way back to the battery switch and then to the battery banks. Minimal voltage drop compared to the 10GA circuit and much less resistance and heat without going through all that small wire and two trailer connectors.
And yes the ammeter will no longer work.
Oct 9, 2008
1,742
Ok thanks. I'll disconnect the orange. Then reconnect when I rem the ammeter and replace with volt.
Oct 9, 2008
1,742
1. You'd best ask Maine Sail directly. 2. Why would you do the mod and not do everything he suggests? 3. Here's the WHY about the original wiring: OEM 1-2-B Switch Wiring History http://c34.org/bbs/index.php/topic,4949.msg30101.html#msg30101 Assuming you have the stock setup, and are moving the AO to the house bank, if you truly understand the logic about the wiring, the orange wire between the starter/solenoid and the alternator makes sense in the old scheme, but not the new one, if you are switching (pi!) between a charge 1-2-B switch and a use switch. http://c34.org/bbs/index.php/topic,4949.msg30101.html#msg30101
Thanks. I am doing it as suggested. With one additional curiosity, now answered. And quickly! :) I love this forum.
I know the why, hence the project. I've never had trouble with it, and have inspected the connectors which look new. But the mod is so easy.
The charge wire goes to the starter batt cable after the ammeter, the batt cable goes to the 1-2-both batt switch. 2 deep cycle group 27's no designated house or starting.
Oct 9, 2008
1,742
BTW the charger is a dual bank connected independently directly to each batt.
No echo charger or other battery gear.
11,709
No it won't work...
You replace the ammeter with a volt meter or you install an ammeter with external shunt, and do so in a safe manner, and in the amp rating needed for that circuit.........
Mod will not decrease the load on the alt but it will greatly help your batteries attain the proper voltage. That circuit leads to high resistance and voltage drop at the battery end but the alt still works just as hard...
Oct 9, 2008
1,742
I'm glad you got your answer, but if you disconnect it as Maine Sail stated, then why would you assume it would work? Just askin', not trying to argue.
Dunno. Just curious. This is how I've learned so much on this board. 17 years working on boats, 10 years sailing, former avid motorcyclist many bikes, plus was a hot-rodder long ago. Engines and boats are in my blood, and still learn new stuff here all the time, and much faster and with greater clarity than before the internet and discovery of this fabulous forum.
Edit: I didn't assume it would work if disconnected, I was wondering if it (ammeter) would work if stayed connected but with the jumper.
Oct 9, 2008
1,742
No it won't work... You replace the ammeter with a volt meter or you install an ammeter with external shunt, and do so in a safe manner, and in the amp rating needed for that circuit......... Mod will not decrease the load on the alt but it will greatly help your batteries attain the proper voltage. That circuit leads to high resistance and voltage drop at the battery end but the alt still works just as hard...
Thank you again.
I'll be switching to a volt meter.
Now I get it. Your question, that is. :):):)
Think of the circuit. Would current flow through the shunt (and therefore the ammeter) if the circuit had bigger wires further "up the food chain?"
Hmm, I'll have to think about that, but golf is in a playoff! :eek:
Nice background you shared.
Here's some more sources of info for you:
Critical Upgrades http://c34.org/bbs/index.php/topic,5078.0.html
Electrical Systems 101 http://c34.org/bbs/index.php/topic,5977.0.html
http://www.c34.org/wiki/index.php?title=Diesel_Engine
Different boats, same danged SYSTEMS. Poke around our website, parallels and supports and links to Maine Sail's excellent info.
Hunter 34 Alameda CA
No it won't work...
This thread was especially timely for me. I am now sold going direct from the alternator to the house bank with the properly sized large gauge wire (numerically small number). I missed the article the first time around (or the 10th, who knows why). I have been flying blind forever utilizing an ammeter and the 10 ga wire. In the last two months since I installed a Balmer Smart Gauge and have seen that my batteries don't seem to charge while motoring. Just today, I returned from a cruise-out where I deliberately left the shore charger off for 2 days. My SOC was 86% when we left the dock this am and motored for 2 hours. After arriving I checked the SOC and it was 84%! The charging voltage while running at 3000 rpm per the Balmer was 13.8 V (duh, living and learning). The batteries prior to leaving (at 86%) were about 12.5 V. I'm just using the stock Hitachi alternator that came with my 3GMF22 engine. I'm charging 4 Trojan 6V batteries and via a combiner, a Group 27 starting battery. All flooded (starter is a maintenance free).
I already have a voltmeter on my (home made) panel along with oil pressure and engine temperature. I would sure like to continue with a functional ammeter but at least today can't seem to find a 2" round gauge style ammeter with an external shunt. Any sources come to mind?
Allan
Mar 20, 2012
3,983
electricity will always take the path of least resistance... and the whole point of adding the large red wire is to lower the resistance so the electricity can flow easier thru it, rather than thru the higher resistance orange wire.... if you left the orange wire in the circuit, you may get a residual reading, but i doubt it, and if you did it would never be accurate...
if you need to know the amps for testing and troubleshooting, you could get an old style inductive meter and read from the red wire without any connections at all....
Mar 20, 2012
3,983
Allan
an external shunt or remote shunt?... they can be different.
here is a bluesea ammeter with a remote shunt, which is better...
scroll down thru it to see part numbers....
Thanks Centerline for the link. Unfortunatly Blue Sea meters have a rectangular face and I have round, weatherproof covers for my gauges. I was planning on converting the wiring (which I will do anyway), then with a remote shunt in series with that, use the existing 10 ga wire up to the existing ammeter location. There I would replace the current ammeter with a new one. Maybe I could take the old one apart and relocate the internal shunt?
The search continues.
3,983
check with your local auto electric rebuilder.... where they rebuild starters and alternators, they should know suppliers that carry what you want...
11,709
If you want a true ammeter they are best installed inside the boat. The engine panel is really only well served to show you whether the alt is working or not and a volt meter does this. The Blue Sea Ammeter fits a standard 2" hole but for the cost I prefer to see them down below...
The best value for an ammeter, which comes with a 500A shunt, is the Victron BMV-600 battery monitor but it does a lot more than just monitor amperage.
