-updated 3/28- Done.
We know the old alt brackets on M25's are prone to failure. However, I cannot find any specific info re where on the bracket they failed.
I've seen pics that Main posted that show the timing case failing(attached), but not the bracket. So I'm wondering how the timing case failed in that picture without the bracket failing. Was it loosely adjusted etc. Or maybe I just can't see the bracket failure in the picture.
So where does the bracket fail? Is it the adjusting arm? The lower bracket itself? The bolts? The equipment to which it's mounted? (-IE the timing case ear) Please no warnings about should the bracket be changed, it's your boat\choice, all that. Aware that they have failed in the past. Just curious how they fail. Mine is the M-18 which I can't find a single documented failure, only one chap who had a crack. Also, I've discovered that the new bracket requires slightly more space to port, and my engine room is spaced such that I would have to modify it :-0 to enable the new bracket upgrade installation. So am looking at options IE: a custom solid steel adjusting bracket, quality bolts, etc if in fact they are the failure points. I just don't know the failure point.
