NO!!!So the M-25XPB uses the Oberdorfer N202M-16 with no alterations. Is this correct?
It seems when you start getting into different models and sizes of Catalinas it all goes hay wire.
Cheers
2 Old Pirates
Thanks for the feed back guys your the best.
No model from Oberdorfer will fit the M-25XPB stock.
You will have to alter the base as I have shown. I have been talking with another 310 owner up here how did the alteration in an afternoon just as I did. If you want the better performing pump, order the Oberdorfer N202M-16. You can use the fittings from your Sherwood pump for the hose connections but you will need to cut off part of the base so it can fit on the motor.
