The safety valve is lower than the hot water outlet so it really isn't able to hold air but I did purge it "just in case" after I descaled the inside of the tank.Have ya tried to pop the safety valve lever with water cold but pressured up by the pump?
This was the reason I bought the inspection camera although it is really handy for finding lost nuts and bolt and checking the prop and shaft for fouling and zincs without getting wet, BBRRR!!pull the electric heating element out and take your camera and look inside to see if you have a lot of scale build up in there on the engine heating tubes
opps just saw your camera post sorry
I bought and installed the WH in 2006. it was sold under the Force 10 name at that time but Kuuma confirmed it is the same unit as their current one.How old is the Kumma?
PS - sorry if you mentioned it earlier, but I read most of this yesterday.
PPS - as another check, have you disconnected the flow to the heater and red dot by placing a 3/8" hose from the thermostat back to the engine? This is the way the engines were shipped before they installed the water heater.
Hayden,1. I bought and installed the WH in 2006. it was sold under the Force 10 name at that time but Kuuma confirmed it is the same unit as their current one.
2. I will give reinstalling the bypass line to see if I can get the engine up to temp.
My original WH lasted for 18 years and finally died due to a leak that appeared to start from rust on the painted outer case that grew into the inner tank. I am hopping that this one will last longer given that the tank and case are all aluminum.Hayden,
1. Our experience is that the heaters most of us C34-ers have are good for anywhere from 6 to 12 years. I just replaced my Seaward S600 last year (2104) for one that was installed when we bought the boat in 1998, and the PO replaced it for this 1986 boat. You could be at the "end of shelf life" time.
2. Look forward to hearing the results.
BTW, I may have sent you this link earlier, but one of our skippers did this, seems to be more like your piping than the one Charles sent you for the Force 10 hater (primary/secondary loops). http://www.c34.org/wiki/index.php?title=Cabin_Heater
Good luck, please keep us posted.
PS Damnit!!! No rum was consumed in the preparation of this post! I should get on the boat!
It's 3/8" ID hose, 'cuz that's the size of the connections on the engine thermostat housing. Most boats expand that to 5/8" to run to the water heater. There have been thousands of Universal M25 engines (21 hp) installed in boats and that's how they work. Mine works just fine, 28 years on.Possibly unrelated, given that your Red Dot works, but I'm amazed that you get any hot water our of your engine with 3/8" OD fittings.
Is the heater and WH wired in series, or in parallel(both fed through a TEE fitting)?1988 M25XP factory configuration. ...the mystery continues.
WH and RedDot are in series. WH gets water first with in at 140F and out at 137F. the RedDot gets what is left, in at 137F and out at 100F or lower.Is the heater and WH wired in series, or in parallel(both fed through a TEE fitting)?
The factory Seaward WH made hot water in about an hour and was only replaced because it developed a leak. The Kuuma was installed EXACTLY the same way with the same hoses.Did the prior system work before you undertook replacement? Did your present installation (#29) ever work from the start?
My Neighbor’s WH is hooked up to the thermostat bypass just like mine. The only difference is that he does not have a RedDot heater. Because the RedDot uses the coolant that has already gone through the WH this should not make any difference."
If not - since your dock neighbor has had success despite the same cold sea water - have you compared his pipe and tube layout to yours?
I have attached the FACTORY SCHEMATIC for the force10/Kuuma WH. Please note that the WH IS on a bypass circuit and NOT in the PRIMARY circuit. I confirmed with the Kuuma Tech rep that the bypass loop is how Kuuma prefers it to be plumbed because they do not want a restriction in the WH circuit to affect total engine cooling capacity."
I realize that you are not willing to follow the Kuuma factory design - relying instead on the (so far unsuccessful) layout based on "that which you have been told" - but what have you got to lose by trying these other options?
I have no idea what you mean by horizontal and vertical layout but I will try adding some info to see if I can clarify. My WH came with a Temperature Control Valve (CTV) installed and I had always blamed it for the lack of performance. Last year I contacted the Kuuma tech department and they told me that the CTV’s have kind of gone out of fashion and I could remove it without causing any problem other than the potential for the water getting to scalding temperatures. Last year I removed it but got no performance increase. So you are correct, there is no temperature compensation control.Mr. Watson is convinced the flow arrangement (the horizontal layout) is just fine and the water heater evidently does not have temperature compensation control.
We do not know about the vertical layout. If the water heater is above the coolant reservoir and the Red Dot is below then wouldn't that explain why the water heater does not heat whereas the Red Dot does?
Charles
The temperature readings were taken using an infrared thermometer using the techniques given by Maine Sail on his "How To" article "engine temp monitoring & overheating baseline assessment." at the following website. http://www.marinehowto.com/ Great source of info, THANKS Maine Sail!!Last thought and it has to do with the process and accuracy of the temperature readings taken. Did you disconnect the outlet hose and collected a water sample and measured its temperature or did you use an indirect measuring device on the outlet line. If there is no flow the temperature difference could perhaps be attributed to that transferred through the metal while the volume of water inside the exchanger remains cool. I don't know exactly how the Red Dot heater is installed and if it would be an accurate indication that there is flow. The exchanger is made of aluminum and is adequate in size so the only other two variables are flow or temperatures. We are assuming we have continuous flow and a true outlet water temperature of 134 degrees. One of these two assumptions is wrong.
