hot water from inverter
Apr 5, 2009
3,327
Can an inverter be used to run the hot water heater while running the engine to charge batteries?
I have a single 210 AH Lifeline 4D for my house bank. The previous owner installed an Ample Power 109A alternator and even with the low internal resistance of the Lifeline I rarely see more than 70A of output. can I use this excess charging capacity to heat water with the 120v element with an inverter?
If this is possible, what would be a good inverter to buy?
Nov 14, 2013
200
Catalina 50 Seattle
Even assuming that your alternator could put out full rated power for an extended period of time without overheating, the extra ~40A of output will only amount to about 400W of AC power to the heater after efficiency losses.
If your water heater's already using waste heat from your engine, it may incrementally speed the time it takes to reach temp but it's basically unnecessary and will put a lot of extra wear and tear on your belts, alternator, and inverter.
Beneteau 323 Annapolis MD
As long as you install a circuit breaker lock-out so you don't run the battery charger at the same time you use the inverter.
7,725
Alden 50 Sarasota, Florida
This isn't the first time someone asked this question. Short answer - impractical with your elec system.
If you want details, please try searching the archives here which is full of similar detailed discussion.
Nov 6, 2006
10,244
Most water heaters have a 1200-1500 watt element in 'em.. Your alternator can make (70 amperes X 14volts =) 980 watts so you'd be using battery to make up the difference until that got sucked dry. (you'd be pulling 50 plus amperes from the battery for, say, 30 minutes to get the tank hot initially.. only 25 ampere hours, but then ya have to replace that with the same alternator.. gonna fry it) To answer your question, yes it can be done with a 2000 watt rated inverter and a good installation (heavy wires and heavy terminals) .. but it is probably not a good idea .. as Istream noted, better to use waste heat from the engine to heat the water.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Water heater
I have a 2500 inverter/charger and I am guessing when boat at the factory
they made sure the water heater can't work off the inverter and also the AC
can't work off the inverter either and that is how it is wired.
If you are running the motor any way that should be making hot water any
way, I run either shore power or my Fisher Panda Gen for my hot water heater.
Nick
Feb 6, 1998
11,767
If you have the typical Catalina 30 Seward water heater the element is usually 1500W.
1500W / 11.5V = 130A X 1.15 (inv efficiency) = 150A Load
You have 70A to work with so 150A - 70A = 80A battery load.
Lifeline Peukert 1.12 = Peukert corrected load of 103A at the battery......
Heat with the engine...;)
Another way to explain what the guys are telling you is that your initial question indicates that you need to address your entire ELECTRICAL SYSTEM design. It is not only the size of the inverter that is involved. If you have't yet, buy Charlie Wing's electrical book and learn about balanced electrical systems based on their intended use.
Apr 5, 2009
3,327
I have been trying for years to heat the water with the engine but on my boat it just doesn't work. I have an older tread trying to solve that problem. http://forums.catalina.sailboatowners.com/showthread.php?p=1133153&highlight=hayden
in a test last year I got a 3º rise in outlet temperature after an hour of running at cruise speed. The coolant loop from the engine drops from 140º to 134º across the exchanger in the water heater. I have a RedDot heater down stream in this loop and the coolant temp drops from 134º to 97º across it even though the fan is not running.
It is a force 10/Kuuma 6 gallon heater. I have checked for flow in the loop and it is unobstructed. There are no bubbles in the system (purged with continuous flow from an axillary pump.) I used an optical scope to inspect the inside of the tank for buildup on the heat exchanger and it is clean.
Last year I motored for 6 hours and got warm water. The Admiral is not happy.
Hayden,
I went back an reread your earlier post.
What engine do you have? How old is the Kumma heater?
Stu
Feb 6, 1998
11,767
With 140 degree engine temps it sounds like a raw water cooled engine? If that is the case then you will have a very tough time getting hot water...
Apr 5, 2009
3,327
The engine is the original Universial M25XP. I also have a old thread about the engine not heating up. http://forums.catalina.sailboatowners.com/showthread.php?p=1139855&highlight=hayden
As I stated in that thread, I have tried 3 brand new 160º thermostats with no improvement. I have tested all of them on the stove (before and after installation) and they open right at 160º. I used my infrared thermometer to check the engine heat at the thermostat housing, block and cooling jacket at the exhaust manifold and it acts like there is nothing in the thermostat housing at all. I am thinking about putting duct tape in place of the thermostat to see if I can force the engine to heat up.
Apr 5, 2009
3,327
Regardless of the input heat not being at the specified 160º I should still get SOME heat from the exchanger. Input water 140º. Tank water 60º. Deferential 80º between tank and exchanger. Guestimate of exchanger 30" long by 1/2"ø = ~48 sq-in contact for water-water exchange. I only get a 3º drop across the exchanger. remember, I am seeing a 37º drop across a water / air exchanger without the fan running and it is down stream of the water heater.
I don't remember everything that I learned in thermodynamics engineering class but I do know that it would take a damn fine insulator to stop that much heat flow.
I talked tot he Kuuma engineering department and they tell me that with 140º water I should have no problems getting hot water in less than an hour. they said that after 1 - 1.5 hours the exchanger loop and the tank should be nearly the same temperature.
Even when I had a blocked coolant heat exchanger and was overheating at 200º I never got more than warm water no matter how long I motored.
Feb 6, 1998
11,767
Check for a bypass valve in that circuit, some Catalina's had them.......
Apr 5, 2009
3,327
There is no bypass. I have checked the flow at several locations along the loop with a water bucket and it flows freely.
If there was a bypass the temperature at the water heater would be close to ambient rather than at the same temp as the outlet from the thermostat bypass port.
Feb 6, 1998
11,767
They used to use gate valves and the gate can be partially closed and cause what you are seeing...... But if you don't have a valve then maybe it is just plumbed wrong.. What engine is this?
Apr 5, 2009
3,327
Are you quite sure that the hoses from the engine to the water heater are clear?
I wasn't. :):):)
http://c34.org/bbs/index.php/topic,3769.0.html
That is one ugly hose. I have owned Papillon since 98 and I have not replaced them.
Papillon is a 1988 so she is 27 this year and it looks like you replaced your hoses at 21 so I am probably due.
I don't really think that is the problem because the engine supplied cabin heater that is plumbed after the hot water makes plenty of heat. the really weird thing is that inlet and outlet temp of the hoses to the water heater are only 3º different. Kuuma says that it should drop 30º or more.
Apr 5, 2009
3,327
1988 M25XP factory configuration. No gate valve. I have connected a drill mounted pump to the return and connected a clear supply line to the hot water inlet and it flows just fine.
the mystery continues.
