Galynd,
I ordered and received (today) two of the Renogy 100 W panels. A couple of thoughts...
One arrived damaged; :cry:
The box was torn and the clear plastic over the cells had a couple of foggy white streaks across it. This might have been caused by the break of the box. The plastic also had a number of ripples across it in a couple of areas. I do not think the ripples were we caused by damage. It was poor manufacturing.
When tested side by side for open voltage, it was about 0.2 volt lower than the other panel. When the replacement arrives I will take them to the boat and do an Amp generation test and provide feedback on that, I expect some time next week.
I spent a bit more $ on them, as I ordered from Amazon and am sending it back for a NO COST replacement.
In general;
1. the panels are NOT very robust and will need to be "babied" to insure they are not damaged. Of all the panels I have seen, they are the weakest, structurally speaking.
2. The edges of the panels are sharp, like a cut 1/8 inch thick plastic sheet.
3. The wires for connecting them up do not look well secured to the panel.
4. The grommets for securing them are small!
On the good side;
1. they are small for 100 Watts
2. they are light weight
I think they would best be used by mounting them to a secure hard top or the like that will never see any contact.
Hope this helps some one out there.
In general;
On the good side;
