There is a lot of discussion on swapping out the Sherwood G-908 raw water pump for the Oberdorfer N202M pump. The big advantage is the Oberdorfer allows easy access to the impeller. On the Sherwood, the entire pump must be removed to change out the impeller. The following is for the Universal (Westerbeke) M-25XPB engine on my 2005 C-310.
The Oberdorfer N202M-908 is a direct drop in replacement for the Sherwood G-908. The threads on the N202M-908 match the hose fittings on the Sherwood. Note that older versions of the M-25 use a Sherwood with a mounting flange. I don't know the part number for that Sherwood. The G-908 on my M-25XPB doesn't have a mounting flange, it uses two clamps, one one either side of the pump. The clamps bolt into the block. I'd prefer a flange, but that is not how my block is set up.
Picture 1 shows the Sherwood on my M-25XPB. If you look directly under the pump you can see the evidence of it leaking.
Picture 2 shows my new, just out of the box, Oberdorfer N202M-908. Note the absence of a flange. On the far right is one of the four bolts one extracts to remove the cover plate of the impeller. Easy access!!! Lubricate the impeller before first use. You will be glad you did!
Picture 3 is a close up of one of the clamps holding the Sherwood on my M-25XPB. Note the absence of a flange.
Picture 4 is the installed Oberdorfer.
The process is straight forward, even for folks like me me who have issues using tools (something always goes wrong). Remove the two hoses from the barbs. Yes, I marked mine port and starboard, although it would be very, very difficult to hook them up backwards. A hair dryer might help. Heat the hose, don't burn it. Mine were a PITA to remove. Remove the hose fittings from the Sherwood. You are going to reuse them. Remove the two clamps on the pump. One came out clean. The other required lots of PB Blaster, swearing, and some light tapping with a hammer. Be careful trying to torque these off. If you break them in the block, you are hosed. A mechanic friend drank beer and watched me work. He curtailed my enthusiasm to get a breaker bar to remove the @#! thing. Retain the bolts and clamps, you will reuse them. Remove the Sherwood. Inspect and clean the pump mount, as required. Put in the mounting gasket. Mount the Oberdorfer. Put in the clamps and bolts. Carefully torque down the bolts, alternating sides, and wiggling the pump to ensure it is seated. Reattach the hose fittings, attach the hoses and put on the hose clamps. Check to see if new hose clamps are needed. Fire up the engine and check for leaks.
Pump: Oberdorfer N202M-908
Gasket: Westerbeke 302678
Spare Impeller: Oberdorfer 6593K
The folks at Decopump.com could not have been more helpful!!!!!! If you are going to replace a pump, call them.
