Recently a poster sent me an message asking if my repairs have lasted. I owe the group an update on my repair results since posting what I thought was a complete fix.
My repair did not last.
I suppose the electromechanical interface between the integrated circuit and the substrate has failed. This could be due to incompatible temperature coefficients between the substrate or it's coatings and the flipped chip integrated circuit and its solder balls.
I suppose disassembly changed the mechanical stress on the substrate resulting in temporary reconnection of the broken IC/substrate interconnect. I was fooled by this. Months later, reassembled and back in service, temperature cycles, vibration and humidity ultimately caused the unit to fail again, within months, in the same way.
I now have a separate engine hour meter and have abandoned the use of the LCD display for logging engine hours. Just like everyone else.
Others who have posted, report new units failing in the same way, in the same time frame as previous units. It seems there is no hope for a reliable unit replacement.
Sincerely, Dale, S/V North Star
