1994 H26
Kermit
Jul 31, 2010
5,722
Just a few minutes in the oven. Then suppertime.
I know it seems a little facebookie. It's Dave's fault.
105
Hunter H31 VISA
Thank you all for your help. Dave thank you for the offer to make the spacers but if your time is limited I could make them if you can send me some dimensions. Also, does anyone know where I could get the spacer that is mounted at the rear of the rudder that runs perpendicular to the tiller? Thanks again
-na -NA Anywhere USA
I have the material for his parts and will be forwarding what is needed to him as he lives locally iand sails in a lake where I started my business way back when.
Not sure if the store site has what he needs. Phil, can you advise on the shims.
Fred
Sep 27, 2008
517
Catalina 28 mkii 745 Ottawa, Ontario, CA
I would also be interested in replacement shims! Mine are disintegrating.
Fred;
First lets see if this forum site's store sells them.
PHIL HERRING< do you have those shims for the Hunter 26 that are placed between the tiller and rudder head housing???????
Larry;
Thank you for advising. If you need help with your installation, feel free to contact me as I know that all too well. Just remember the CB line is 7/17 and the other I suggest a continuous line about 20 feet of 3/8.
Kermit
Jul 31, 2010
5,722
Larry;
Wow, I'm not sure where he'll find 7/17 line. Will 7/16 suffice? ;-) I love you man!!!
Fred
Sep 27, 2008
517
Larry.... What exactly are the parts you are expecting from SBO store? Does it include the flat spacer plates? How much did they charge?
Fred
Sep 27, 2008
517
I found the spacer plates on the store site. Thanks
May 2, 2014
76
Hunter 26 Home port Cape Coral
Fred
I'm looking at your picture and it looks like you have an extended Bimini, more than 6'. Are you able to sail with it up. I ask because my Bimini is extended. Haven't sailed since it was installed.
Larry
Fred
Sep 27, 2008
517
Yes I sail with it up. I adjusted it so that the boom clears it. The main sheet is attached at the second ring on the boom so it also passes in front of the Bimini. I'll check if I have a better pic.
Fred
Sep 27, 2008
517
I bought, received and installed the rudder spacer plates from the SBO store. They fit well and now my tiller can be lifted and stays at the position that I leave it.
