Working on the boat again today. One new problem caused by the ice chest..
I have a car stereo in the boat with four 8 ohm bookshelf speakers. It uses between 1 to 1.5 amps with closer to 1 amp being typical. The book shelf speakers were all auditioned to the sound I like and I also have two 10,000 uf capacitors on the DC power input to the stereo - very close to the stereo.
Anyhow, in my opinion, it is a very fine clean sounding stereo even at fairly high volume (I think part of that is because of the capacitor).
The two bookshelf speakers in the back have always sounded good. But.. I had to move the front speakers a bunch of times to get them to sound good because that nice big area up front with all the bare gelcoat really reflects the sound and also has some annoying mid frequency resonance.
You can see where I ended up putting the two front speakers and the one on the port side down low was the biggest hassle. That speaker is actually facing up mostly because it sounded better that way, also the speaker cone can’t get kicked since it is at foot level.
When I put in the new wood piece for the ice chest and removed what was there before (including a seat pad), all of a sudden a new "mid" resonance came back. I have the problem partly solved now with different baffle and sound absorbent material (some fleece gloves which are just temporary so see what helps)..
