Propeller nut woes...
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
Put a new propeller on my 1" shaft.
The old propeller was held on by two nuts and no cotter pin. I ordered a castle nut but even utilizing the thinner jam nut I can not get access to the cotter pin hole in the shaft. I need about another 1/4" before the hole lines up and there is too little meat left on the shaft to drill a new cotter pin hole.
Any suggestions? I really do want to use a cotter pin here.
678
Just had a though while looking at the pictures I posted. Could I put the castle nut on with the crown forward if the hole lines up?
Feb 20, 2011
8,062
Just tossing this out there-
Think you could shim it with some bronze/aluminum/stainless washers?
Nov 7, 2012
678
I was thinking of that. Just ditching the second nut and going with stainless washers and the castle nut/ cotter pin. Is it bad mojo jnot to have two nuts?
:p
Jan 4, 2006
7,577
Don't know how it would affect your mojo but I suspect it would have a significant effect on your voice :redface:.
Barring that, and if you're determined to have a lock nut, any chance you could grind down the leading lock nut until it was the right thickness ? Doesn't look like it would take much until you could get a pin into the castle nut.
However, if that won't work, I agree with justsomeguy that a single castle nut and shim washers would be preferable and the cotter pin is mandatory. Lock nuts alone just aren't secure enough.
The attached shows a single castle nut and pin on our boat. If I'm not mistaken, I think most boats I've seen while working on the hard only have a single crown nut and pin.
Apex
Jun 19, 2013
1,222
C&C 30 Elk Rapids
Did you lap in the propeller? You may get the added distance and more secure propeller fitment.
Aug 8, 2006
340
Catalina 34 Naples FL
I noticed your prop has a flair at the ends of the blades like winglets on an airplane. What is that? I have not seen this before.
Nov 7, 2012
678
It's an Indigo 3 blade. They designed it just for the Atomic 4. Folks say you can get about 2k +rpm and 6.5 knots out of it on a Catalina 30. Good reverse also. Hope all the fan fair is justified.
Nov 7, 2012
678
I think I will try that. Still have the puller so nothing to loose.
