That'll work out nicely. That's when the snow will have finally stopped! :dance:Well, this is a bummer. Ordered the SmartPlug and it is on BACK ORDER and won't arrive until the second week of March. ...![]()
Yep, ad that one to the list, number 100,046 and counting...Just found out yesterday, a friend at marina next to mine had a fire onboard last week. Bet you can't guess where the fire started.....shore power plug on the boat. No significant damage, was caught before it got out of hand. He was on board at the time and started smelling it beginning to cook...very lucky he was there. It would have taken several boats along with his.....
yea and most will not make the change till they see a boat close by catch fire and burn...funny how people procrastinate the important stuff ....and then it will be like locking the gate to the paddock after the horse is out....I upgraded my power cords and connectors to Smart Plugs last year. The scarey part is that there is only one other boat in the marina with this same upgrade(installed by MS of course). But so much potential for fires while I have made the investment to be safer.
Sadly this has only a little to do with just keeping the contacts clean... I wish it were that easy. The twist-lock design allows movement, this causes the female socket spring mechanism to loosen over time, this coupled with less contact surface area than a standard house hold 15A outlet, and boaters trying to push 30A through them, and no matter how clean the contacts fires can be started."IMHO boaters who stick with the twist lock standard are a "statistic waiting to happen".....:cry:"
ALCON,
I disagree with this statement on some levels. I do agree that twist lock is not nearly as good as the smart plug but I believe that when properly maintained with dielectric grease they can be very safe. As I stated in my previous post I had huge problems with my twist lock plugs in the past that use of dielectric grease complete resolved. On the plus side a tube of dielectric grease only costs a few bucks. Far less expensive than replacing the entire outlet with a smart plug if you are willing to put in the 5 minutes a few times a year to keep your plug prongs covered.
Just my 2 cents... feel free to ignore at will.
Take care,
-Levin
Dielectric grease is an INSULATOR. This comes up so often....
woody, do you get a different taste with the different colors? :Liar:yea and the dang stuff tastes funny
Stu funny you should ask........only the bluewoody, do you get a different taste with the different colors? :Liar:![]()
Even a 50A service does not require 4GA. Are you sure you are looking at AC wires and not DC? 30A service is 10GA, 50A service is 6GA... Is it possible you had a 50A service?Have 4awg cable from my shorepower plug to the AC panel
Smart Plug only opens up to 10awg anyone find a crimp end somewhere that will adapt 10 to 4
Thanks
To do this correctly and safely you will need:Maine
Its a 30A setup panel can accept 4awg cable so thats what I want to run to the smart plug
Looking for a crimp style adapter to take 4 down to 10 so that I can make the connection
Otherwise I was going to reduce the cable at the plug so it will fit in
Thanks
