Lite Propane Tank Recall
CYQK
Sep 11, 2009
610
beneteau first 42 kenora
So I looked up the model/serial number of my tanks and there it was mine are effected
Does anyone know what actually happened to warrant the recall
Anybody know what happens now that Lite Cylinder Company is closed down?
Thanks
Gary
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I think we are screwed :cry: the dealer that sold them does not want consider it his problem. They should not be refilled.
I still have my steel tanks and they are usable. I may buy the Worthington 10 lb aluminum tanks from Amazon for $110 each. They look like they will fit in our boat.
Good luck, Bob
WayneH
Tartan 37 287 Pensacola, FL
Buy a Trident tank from right here at SBO, item # [FONT=verdana, arial, helvetica]206728. Only the Lite Cylinder tanks were recalled. [/FONT]
Personally, mine is hung out over the fantail and I'm going to use it until the guys down the street at the RV park get wise and refuse to refill it. The failure rate for the 25# cylinder is lower than the failure rate of the guys next to you on the highway. Flame me if you want to but it has rode the stern rail for two summers under a dark green cover and still has propane in it.
Nov 6, 2006
10,253
Paint it all white and take it to a Blue Rhino exchange station??
Nov 6, 2006
10,253
Laughing, No, Bob, but I have been accused of being a cheap ash engineer.
Gunni
Mar 16, 2010
5,937
Apparently the jack-legs that were building the Lite composite tanks took a perfectly fine design and assembled it using shoddy practices and poor quality control. Then they shut their doors faster than you can say Freedom Industries, leaving others holding the bag. So your individual tank may not disintegrate, but it may also blow up. And no, you don't get compensated. Me, I used up the remaining gas, and opened the valve. My tank sits out in the hazmat shed waiting for it's day at the firing range. Lesson learned.
CYQK
Sep 11, 2009
610
Sorry to hear your in the same boat Gunni
Does anyone think they can be used up on your barbeque to use up the gas without dying
May 16, 2007
1,509
I think the issue was they could crack and leak. If the BBQ is outside (not in the garage) it is probably not much of a hazard. I think it is a good idea to remove it from a boat because of possible insurance issues should there be a fire, even if the tank had nothing to do with it. From what I read I believe it was the bigger tanks that had the issues and complaints. Also they were unable to produce proper testing data proving the tanks passed required standards when they were asked for it. I think the lack of data caused them to be shut down and with no sales they went under quickly.
Bob
Sep 20, 2006
2,955
Read the other thread that is now a sticky on this forum and linked above in my post. It has links to the recall notices regarding stopping use of the cylinder. We can't advise you any further.
Continuing to do so is your call, but I don't think I'll make it to your BBQ party. ;)
Gunni
Mar 16, 2010
5,937
In my case it was a calculated risk. I left it in place undisturbed and used up the gas believing that jostling it around in the pickup trying to get it to my propane mechanic was riskier.
Feb 20, 2011
8,062
snip- My tank sits out in the hazmat shed waiting for it's day at the firing range. Lesson learned.
That's a good idea, Gunni. Once holed, the recyclers will take it. (Edit- Oops, they're fiberglass. Never mind recycling.)
Could be even more fun with incendiaries...
zeehag
Mar 26, 2009
3,198
COULD crack and leak
or
DO crack and leak?????
have any cruisers experienced crack and leak????
how many have ACTUALLY cracked and leaked.....
curiosity has the best of me, so i wanna know.
CYQK
Sep 11, 2009
610
Justsomeguy
Ihave two full twenty pounders thought about taking them out on the ice in front of the house and blasting away with the 30-06
Have shot metal tanks but never plastic ones,wonder if the impact would cause an ignition??
Might as well have fun with this instead of a pity party
Just sayin!!!
Feb 20, 2011
8,062
Justsomeguy
Just sayin!!!
With standard ammo, they won't blow up like in the movies, but I'd still advise caution.;)
Jun 7, 2007
28
- - Newport Beach CA
I purchased my tank from West Marine and after the recall, I received a $100 dollar
gift certificate from WM and a new tank from Lehr Corporation at no charge.
CYQK
Sep 11, 2009
610
WayneH
WELL!!!!!!!
Learned a new word this morning tannerite
Watched the videos on YOUTUBE holy crap
Sure the NSA has now got me on their list
Thanks
