Soldering wiring connections
Catalina 30 Mandeville, La.
I solder enough to know that a crimped and soldered connection is a very good connection. Put a little rosin core flux on the bare wire crimp then solder. The solder will flow to the heat and the flux will let the liquid solder flow around every strand. You can recognize a cold solder connection by the dull appearance as opposed to the shine appearance of properly solder joint. I do not solder every joint only ones I feel which benefit form the effort.
The correct electrical solder will not corrode a connection I have a collection of tube ham gear some of with is pre WWII and the connections are in excellent shape even the home brew radios and Kit builds.
Start dumping fresh and saltwater on a connection and all bets are off.
I used to tin the wire then crimp a terminal or butt splice, then someone on this board suggested this method of crimping and then soldering. It was pointed out that the solder on the pretinned wire can crack when crimped. I must admit, I don't crimp and solder much, but have used tinned wire with good results.
Jim, you work any of the local repeaters much? I haven't been on 2 meters much except for ARES nets and emergency drills. Maybe I'll run into you at the hamfest in Hammond next month if you make it there.
Jan 10, 2011
370
Macgregor 25 675 Lake Lanier
So I guess you don't approve of the electrical that came with my boat. All the wires were connected using something like the 3M SCOTCHLOK Quick Splice Wire Connectors.
http://www.etrailer.com/Accessories-and-Parts/3M/804C.html?feed=npn&gclid=CLD-5_qn1rsCFU5o7AodgwMAzw
The lights worked sometimes:D
11,756
My 2¢.....
It is important to note that the ABYC does NOT ban the use of solder on boats. It makes suggestions about how to more safely use solder on a boat and that suggestion is a mechanical connection, then solder, and then properly strain relieved. In my 35+ years on and around and working on boats I can practically count on one hand the number of times I have come across "properly" soldered wire joints. Okay it's really more than that but the point is most solder joints I come across in the marine environment SUCK because they were IMPROPERLY executed....
Over the last 35+ years having worked in three different boat yards, on "mega-yachts", with a friend who is a marine surveyor and on my own boats and customers boats it has allowed me to see with a large, n=xxxxx, of solder failures. On your own boat, n=1, failures might be quite rare, but as the n=X grows, n=500, n=3000, n= 5000. n=10,000 etc. so does the rate of failure/success between solder and crimps on boats.
The failure rates I have seen for soldered connections is significantly higher than that of crimped connections. Why? I suspect because most folks just don't know how to do it properly. When done correctly they are fine, and some folks DO know how, but unfortunately that happens very, very rarely, in my experience. The PO of my own boat was an EE and still made horrible and unsafe soldered joints. When it comes to solder it was a pathetic mess when I got it.
Keep these points in mind:
FACT: The ABYC does not prohibit the use of solder only prohibits it as the sole means of mechanical connection.
FACT: No means of wire twisting count as a mechanical connection under ABYC E-11. This was clarified through standards clarification review a number of years ago. WU or Lineman's splices are not intended for stranded wire and are specifically banned under a number of standards including the NASA standards and they also don't count under ABYC.
Here are some other interesting points from ABYC E-11:
"Conductors shall be at least 16 AWG. EXCEPTIONS: 1. 18 AWG conductors may be used if included with other conductors in a sheath and do not extend more than 30 inches (760mm) outside the sheath.” 11.16.1.1.2."
"Conductors used for panelboard or switchboard main feeders, bilge blowers, electronic equipment, navigation lights, and other circuits where voltage drop must be kept to a minimum, shall be sized for a voltage drop not to exceed three percent”.
"Conductors used for lighting, other than navigation lights, and other circuits where voltage drop is not critical, shall be sized for a voltage drop not to exceed 10 percent.”
"Solderless crimp on connectors shall be attached with the type of crimping tools designed for the connector used, and that will produce a connection meeting the requirements of E-11.16.3.3.” 11.16.3.8."
"Current-carrying conductors shall be routed as high as practicable above the bilge water level and other areas where water may accumulate. If conductors must be routed in the bilge or other areas where water may accumulate, the connections shall be watertight.”11.16.4.1.6."
"Terminal connectors shall be the ring or captive spade types.” 11.16.3.4."
"Twist on connectors, i.e., wire nuts, shall not be used.” 11.16.3.6."
"Ring and captive spade type terminal connectors shall be the same nominal size as the stud.” 11.16.4.1.12."
"Solder shall not be the sole means of mechanical connection in any circuit.”11.16.3.7."
Some other things to consider:
FACT: You as a private boater do NOT need to comply with the ABYC
CAUSE FOR CONSIDERATION:
Your surveyor surveys to ABYC standards and your insurance company underwrites your boat based on the surveyors report.
These are just a bit of the "insurance/survey" items I have had to deal with over the last few years:
*Bond a keel stepped mast to external ballast (after a strike claim)
*Bond numerous boats for AC Grounding to DC Grounding
*Add over current protection where it did not exist (house banks for example)
*2 Boats for the AC inlet / breaker 10' rule
*1 Boat for an improper AC main breaker (not double pole)
*Multiple boats for GFCI outlets
*Multiple boats for lack of DC over-current protection
*Multiple boats for LPG system issues
*1 Boat for AC/DC isolation (cover for AC) behind AC/DC panel
*Multiple boats for fuel system issues (too many to list)
*1 Boat for a reverse polarity indicator
*Approx three boats for non compliant battery chargers
*2 Boats for ignition protection issues on gas boats.
*1 Boat for lack of a bilge blower
*Improper bonding of chargers and inverter/chargers
*1 Boat for a bilge pump alarm
*Multiple boats for deteriorated below waterline hoses
*Remove a non compliant on-demand water heater (Excel)
*Multiple battery system compliance issues including venting, acid containment, over current protection etc..
*Multiple unsafe termination issues (solder, wire nuts, improper lug stacking etc.)
*Steering system failures (meat hooks etc.)
There are probably more that I am just forgetting... Insurance companies and surveyors today are playing a CYA game. In todays day and age it does pay to use the available safety standards as a solid guideline for boat upgrades. The survey industry uses them so the closer your boat is to those guidelines (ABYC) the better chance you will have a skating through clean on an insurance survey. It is getting tougher and tougher to find a lick & stick surveyor these days due to the litigious nature of our society. I am sure they are out there but NAMS and SAMS are getting very structured and precise in what they want to see...
Doing the best you can to ensure as close to the safety standards as you can get will ensure passing an insurance survey. Crimp then solder is FINE. Insurance companies are getting much more strict in what they want to see upgraded or fixed in order to maintain insurance coverage. There is no such thing as being "grandfathered" by an insurance company anymore.
I had one owner who pulled the "I'm grandfathered" card on the insurance company and they dropped him at renewal. He had an extremely trough time finding insurance for his forty year old boat. In the end it cost him $700.00+ more per year than the $120.00 in safety requirements the insurance company wanted to see. D'oh!!!!:doh:
NOTE: "Lick & stick" is a term for those of us in states that require State inspection stickers on cars. Anyone who's ever owned an old car knows what a "lick & stick" garage is..... A few extra dollars and the problems just go away and he licks the sticker and slaps it on... (wink)
Points to ponder over:
As one who lives in the North East, where nearly every home has a deep artesian well, with LONG wire runs and fairly high amp draws, we just don't see moisture failures with heat shrink butt connectors.. Yes boats are a humid environment. How humid are the wires sealed 200+ feet below the surface, that live underwater for their entire working life span and then last for 15, 20 years or more or until the well pump fails? Pretty impressive stuff for a heat shrink butt connector. If your boat is submerged for more than a few minutes you have a lot more to worry about.
Keep in mind that nearly every industry uses crimps reliably, without solder, including aerospace, space, automobile, medical, laboratory, truck industry, heavy equipment and have been for years and years and years. I was working on my neighbors John Deer tractor a few months ago and every single connection in that tractor is crimped.
The artesian well at our old house was 245 feet deep and was a true artesian. It over flowed/bubbled out the well cap almost all year. The crimped butt splices were about 240 feet below ground and totally submerged... These wires connecting the well pumps are crimped and adhesive heat shrunk with what are called Stakons (basically adhesive lined butt splices). These bare copper, non-tinned, wires have been under water now for approx 16 years only crimped and heat shrunk. I think that today that same well pump is still going strong..
Crimping solder tinned wire:
If anyone gets really bored NASA has some great wiring standards as does the US Military. It is exciting reading (NOT). My crimp tools all meet or exceed MIL-T- 7928G because it is the most stringent for crimp terminals. The ABYC standards for crimp tensile strength, by comparison, are PATHETIC....
Keep in mind that crimping solid copper wire or solder tinned wire can also damage the dies on the crimp tool and throw it out of calibration..
Here's what NASA's standards have to say:
"4.3.4 Crimping Stranded wire shall be used for crimping (Requirement). Crimping of solid wire is prohibited. Crimping of solder tinned wire is prohibited."
The way I tend to look at it is this way. When you and your boat are far off shore you might as well be in outer space because it is you, you and you who are there to deal with any issues..;) Do what ever you do WELL......
Just because I am an ABYC member and ABYC certified does not mean I stop there. I push to exceed the ABYC standards and that is why I read and study other standards and incorporate them into my own standard of work, especially when they can be beneficial and BETTER than ABYC...
Soldering after a crimp has been made is fine provided you:
*Know what you are doing, IME most don't. (in my line of work that amounts to about 98% of what I come across did not know what they were doing when it came to solder.).
*Use a heat sink to prevent solder creep up the wire.
*Use the correct solder.
*Use the correct wire prep or rosin core solder. (Non-activated R or NC or a high quality RMA rosin core flux from a known and trusted manufacturer are about the only products that should be used in the marine environment. Be aware that there are many RMA fluxes out there that are not acid free. Get this acid into the fine strands and it can be impossible to clean out and will lead to corrosion.)
*Use proper strain relief or adhesive lined heat shrink.
*Use the proper crimp terminals for crimp/solder which are different than typical insulated terminals and rarely as robustly built as the insulated ones or heat shrink ones.
Crimp/solder terminals utilize a B or F type crimp also known as D-Sub etc.. They are extremely tough to find in a good tinned robust build AND they require a specific crimp tool..
Image Courtesy Innova
*Use the proper crimp tool for the solder/crimp terminals which most don't own or have on-hand if they have been using a crimper designed for insulated crimps.
In short doing crimp then solder requires different tools, proper training and more labor than just using a good quality crimp tool and high quality terminals..
There are billions & billions of crimps in use world wide, maybe even trillions. Yes solder makes a great electrical connection, no one would ever dispute that, but apparently it is very tough to do correctly & from what I see on boats...
People botch crimps too, lets not kid ourselves. You can't get caviar results with a dime store tool and dime store terminals, but people try all the time.;)
Nigel Calder from Boat Owners Mechanical & Electrical Manual Pg. 122 said:
Soldering is a controversial subject. A properly soldered connection creates the best electrical connection, but all too often the soldering is not done properly. In any case, ABYC regulations require that every joint have a mechanical means of connection other than solder. The reason for this is that if the joint gets hot (through excessive resistance or a high current flow) the solder may melt and the joint fall apart. So solder often becomes just an adjunct to a crimped connection, but in this case the solder wicking up the cable creates a hard spot, which is then liable to fail from vibration. The consensus among professionals is that a properly made crimp, done with the proper tools, is frequently a more reliable termination than soldering.
It wouldn't have been a complete thread discussion without Mainesail's input which I was waiting for. As usual his detailed response wasn't off the cuff and took some time to compose. And, as usual it shows.
As for me, I'm one of those doing what are probably bad solder jobs. They'd go better if I had four arms. Upside down under whatever with my legs jammed in something and solder dripping near my eyes, it isn't easy. Yet, my crimps suck too. I've bought better tools - not the best - but many fail the post crimp pull test.
My last rewire on my Ankorcraft, which had twisted stranded wire connections all over, was a large improvement over what was there in safety. And a great place to practice my skills. I aspire to do better crimps - and soldering. So how do you use a heat sink?
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
My last rewire on my Ankorcraft, which had twisted stranded wire connections all over, was a large improvement over what was there in safety. And a great place to practice my skills. I aspire to do better crimps...
This should help you make better crimps: http://www.pbase.com/mainecruising/wire_termination
Oct 17, 2011
2,809
Ericson 29 Southport..
My heat sinks usually tend to be my fingers, I've got little burns again today. Really though, if I sink it away, a pair of medical hemostats are my weapon of choice. It's best to 'pre-spring' them so they don't get so aggressive with the wire, and it's way overkill when the two dollar one will work just as well. I just keep several stats in my kit.
I forgot to mention, I've been soldering communication wires the last couple of days. That's why I said I do both, and I'm not sure why exactly I'm 'stuck' on soldering comms. Speaker wire, 0183's, etc are too big a pain to crimp something so small, and after thousands of joints, I can tin the ends, solder them together, slip the shrink tube up on it so fast it'll start to shrink before I can get the gun on it. But it is tough to learn correctly, and why I myself hedge about recommending it. Everything else gets crimped.
Part of the trick with crimps seem to be the wider crimp jaws, obviously getting more compression area. And the ratchet loaded ones are nice, but they generally need 'dialing in', and the absolute correct terminal for the spec out. I use a pair of T&B's that are marginal, but again, after untold, countless crimps with a tool I'm familiar with failures are a long ago thing of the past. I should break down and buy high-dollar crimpers, I've seen Maine's, and that is super nice. My dynamic lifestyle precludes me owning anything much very nice, as too many times through the years has required to to drop everything to go on another witch-hunt of some kind for a year or so, and my tools seem to like other mechanics I guess.
But I guess that is another reason I don't advise crimp, solder one way or the other. One man's skills are another's blunders. And maybe that's why I spend so much time dragging these rat's nest's out of peoples equipment and fixing it right. But you are right Maine. (God that hurts saying that;)) But damn some people have no business messing with wiring, because there are some incredible nightmares out there. If you even GO into auto-shack or whatever those places are to buy crimping tools, just go get drunk instead. Hire somebody to fix it.
And that is another line item on my contract, "Have you already worked on it before?"
"Has your brother-in-law already worked on it before?"
A yes answer to any of these questions, (And there are a whole lot more than that, ie: Are you going to call my phone? Do you intend to leave me any messages on my phone?
These things add up, people.
I will call you at the bar when I'm through. It's better that way..
(I STILL have not got the nerve to open that link on Scotchlocs. Tell me it ain't so, I don't want to look. Seriously).
Oct 17, 2011
2,809
Oh NO!! OH NO! I DID look. It was a flashback from The Pit and the Pendulum. The gaping maws of hell. Sucked into the vortex of evil. Forced into a life of prostitution.
Alright, I had a drink myself. Did you see where it has corrosion RESISTANT gel in it. So, would you like to buy the bullet-proof vest?
Or the bullet resistant vest?
I know that was just funny folks, but I HAVE seen 'em.
You have too, haven't you?
They're in your box, aren't they, c'mon, you can tell ol' uncle Chris, I won't laugh..
Jul 19, 2013
186
Hunter 33 New Orleans
Not much anymore. I will dig out a rig every now and then and play for a few days. I have a APRS Tracker to install on my boat but can't seem to get it nailed down like I want. I have a KWM-2 sitting next to me here and will fire it up every now and again and check into the Maritime net. Really not much radio going on here.
Forrest what is your call? I may get my brothers Fred K8VDU and Charlie N5UXV and make a run to Hammond.
Now back to the black art of soldering.
KD5PKS - I thought I had posted it on the previous entry, but it didn't make the cut apparently. Don't recognize your brothers' callsigns either. It might have stuck since we share the same last name.
11,756
Like anything crimping small communication wires requires the right terminals and the right tools.
Terminating Small Wires
sunman
Jul 29, 2009
112
Mac Mac 26D Suwannee
Ah Huston we have a Problem!
seems the wire crimp wasn't done right and we've lost control of the Robotic arm, it just smashed the Shuttles Bay Doors ...
Buzz is soldering the wire back , but U have any suggestions on what we can do about the Bay Doors befor we try re-entry?
How many crimp conn. in ur marine raido? GPS?
how about corrosion? a properly solderd wire an sealed w/heatshrink tubing has a far better chance then just a crimp...sometimes crimp is all U got, but when and where U can, do it right!
solder it!
I hear the Shuttle vibrated so badly the astronutz eyes would shake & bounce
just saying :)
Oct 8, 2013
42
S2 27 Delaware Bay currently
After being in electronics and telecomm for 30 years I can say that the vast majority of poor connections were obviously going to happen. Obviously, because if someone inspected the joint they would see something wrong. If you forgot your reading glasses or flashlight, go get them because it's well worth squeezing back in to do it right.
7,668
Alden 50 Sarasota, Florida
Which is precisely the reason soldered connections are preferable (if you have the skill). You can identify a bad solder joint by visual inspection.
The only way to identify a bad crimp is through destructive testing.
Nov 18, 2005
73
Beneteau 323 Brookville, IN
Soldering lasts
While I can't claim a lot of blue water experience, I can claim 40 years of sailing and doing all of my own maintenance. I have found soldering, properly performed as noted previously, to be incredibly reliable and my connection of choice for most (i.e. less than 20 amp) connections.
Oct 8, 2013
42
I have to say that I like solder and never liked crimps. I would always follow a crimp with solder. I have come to see that proper crimps can be good. It can actually be worse to solder a crimp if the crimp was poor in the first place. A crimp that's done with the wrong tool or too tight, nicking or weakening the copper through compression, can be worse because the solder covers up the weakness that still exists. It's very easy to become frustrated while crimping and just let something go when you actually do see it. Then it's time to take a breath, strip it again, crimp it again, inspect it again, even if it's the third try on the last wire.
cas206
May 15, 2012
24
Cal 27-3 Solomons
The Ancor single crimp tool doesn't appear to be available anymore. The double crimper is still available as well as:
http://www.marinco.com/product/stainless-steel-cutstripcrimp-tool
http://www.marinco.com/product/cutstripcrimp-tool
(in appearance, resembles the cheap hardware store kind)
and
http://www.marinco.com/product/wire-strip-crimp-tool
Any recommendations on an alternative to the Ancor single crimper?
11,756
Some of you guys may never want to set foot on a plane....:D
I am a rather voracious reader, heck I spent 20+ years reading BOORING medical clinical trials and clinical data. Electrical stuff is far more exciting.
About 10 years ago I was sent a paper by one of the engineers at AMP called:
"CRIMP CONNECTION RELIABILITY
RADC-TR-78-15
Final Technical Report
January 1978"
This analysis and white paper was complied for the US Military by Martin Marietta Corporation. It may be out there on the net but I can't guarantee it.
Here are some highlights from that paper:
RADC-TR-78-15 said:
"This report has been reviewed by the RADC Information Office (01) and is
releasable to the National Technical Information Service (NTIS). At NTIS it
will be releasable to the general public, including foreign nations.
RADC-TR-78-15 has been reviewed and is approved for publication."
RADC-TR-78-15 said:
EVALUATION
This effort supports RADC TPO R-5-B, Solid State Device Reliability.
Appendix A of the report, which includes a prediction model and updated
crimp connection base failure rates, will be included in the next
revision of MIL-HDBK-217B, Reliability Prediction of Electronic Equipment."
Use of this revised and updated model and updated base failure
rates will greatly improve the accuracy of crimp connection reliability
predictions.
The model developed consists of a base failure rate modified by
multiplicative factors for environment, type of crimping tool, and
quality procedures. The failure rate calculated from the model for
a crimp termination in a fixed ground environment is approximately
one order of magnitude less than the value of 0.0073 failures/1,000,000
hours presently given in MIL-HDBK-217B
RADC-TR-78-15 said:
*More than 3.8 billion part hours of collected data were analyzed and
grouped over five operational environments.
*A good crimp connection can withstand high levels of temperature
and vibration, has excellent performance in corrosive environments, and
is reliable.
*Crimping is the most widely used method of pressure connection for
permanent electrical contact between a wire conductor and a wire conductor
terminating device, such as a connector pin. An estimated 70 billion
crimp-type wire terminations are used every year in the United States.
The method's popularity can be attributed to its overall versatility.
The most widely used type of crimp connection is the removable contact
used in connectors. Another class of crimp connections includes terminals
designed for attachment to board, bus, or block with some type of mechanical
fastener. Low cost, high application speed, compatibility with
a wide range of wire sizes, good mechanical strength, and high reliability
are achievable with a crimp connection system.
*The objective of this study program was to develop a crimp connection
failure rate mathematical model based on contemporary data from military
systems that experience varied conditions of application and environment.
The developed model provides a means- for deriving failure rates for crimp
connections under variable conditions and applications. Variables comprising
the model require no more information than is normally available
to engineers during the equipment design phase.
*The theory behind crimp connection is establishment of contact
between two or more electrical conductors by applying mechanical force
to deform metals past their elastic limits. The mechanical force establishes
large area metal-to-metal contact and locks the conductors together
through the process of cold welding and the action of residual elastic
stresses in the conductors. Cleaning contaminants and oxides from conductor
surfaces is also accomplished by a combination of high pressure,
metal flow, and gross deformation of the conductors.
*The right crimp system, i.e., the proper combination of wire, termination,
and tooling, must be used to obtain the optimum crimp geometry.
*As a rule, spliced or crimped conductors, such as a wire and
terminal or wire and connector pin, or even wire to wire, should have an
electrical resistance no greater than an equivalent unspliced or uncrimped
length of conductor; also, mechanical strengths of joints should not be
significantly less than the conductors.
*The crimping operation does not start with freshly cleaned
surfaces, although the crimping action does clean the surfaces to some
extent. Also, the plastic deformation in crimps is much less than with a
normal cold weld. However, there is a sufficient amount of pressure and
associated plastic deformation involved to cause some degree of cold
welding. This produces a gas-tight connection that assures high resistance
to internal corrosion.
*The majority of crimp failures are caused by procedural problems,
such as using the wrong indentation on the crimping tool or using an
incorrect size termination for a given wire gauge. These failures are
usually detected before the equipment is shipped through tensile strength
tests or higher equipment level tests such as acceptance tests that
include functional and limited environmental testing. The causes of
these problems usually can be attributed to negligence and/or poor planning.
*Corrosion of the electrical contact areas causes failure of the
electrical interface. Atmospheric corrosion primarily depends upon the
amount and types of contaminant present in the environment, This type of
corrosion is not a serious problem if the crimp cross section is a true
homogeneous mass and is gas tight, because the corrosive medium has no
access to the contact area.
*Problems that occur in crimped terminations are usually caused by
human error, particularly when manual crimping tools are used,
Conclusions:
Crimped connections are the logical choice among permanent electrical connections
for most applications because of their desirable characteristics,
some of which are:
#1 Stability at high temperatures
#2 No heat involved in the process; possible damage to insulation
prevented
#3 Great tensile strength
#4 High resistance to internal corrosion
#5 High volume production capability
#6 Minimum technician skill required
#7 Reliability in high vibration environments
#8 Repeatability; once inspected for proper setting, tool will provide
identical production terminations.
The above are not my words just the work of our own US Military and Martin Marietta Corporation..
Proper tools, terminals and techniques yield excellent & repeatable results:
Crimped Yellow Terminal & 12GA Wire
Insulation Removed:
Cut at the crimp band:
Another View:
Sep 28, 2008
922
and
The "crimpers" linked to above are all terrible in my opinion. Here is a link to one similar to the one I use, out of stock now though:
http://www.sailorssolutions.com/index.asp?page=ProductDetails&Item=WP042
11,756
and
None of those tools should be used for anything more than stripping the wire..... Unfortunately Ancor discontinued the 702010 tool but you may be able to find it out there.
Some of the best of that style tool, for heat shrink terminals, that I have found, comes from TE Connectivity / AMP 55893-1 or Rennsteig. Most won't want to spring for the Rennsteig tool.... There are some decent knock-offs of the AMP 55893-1 and the Anchor tool was one of them...
