Considering is is generally verboten to crimp to solid conductors, and the average differences between solid and stranded OD is on the order of approx 5%, we are still not even close with the mythical AWG die sizing on the HFT tool..True with regards to conductor cross sectional area but not for conductor diameter due to the number of strands. The number of strands therefore determines the lug size and crimp die required. Generally flexible cables will need larger lugs than building wire cables. Also, flared lugs are made specifically for flexible cables to make it easier to get all of the strands in the barrel so it's interesting that you avoid them![]()
It makes an okay crimp on 4ga with flared lugs but not on anything larger for stranded AWG cable..
