Thanks for the review. What I hear is that the issue with this tool is the dies. I was wondering, since it seems so far off, could it be that they are intended for a different type of crimp terminal than the ones you are using?
For example you describe in some detail on page one of your article that there are different dies for different terminals. Perhaps we're being unfair evaluating this tool for a terminal it was perhaps not intended for.
I have the Ancor lug crimper, and even that has two different die sizes for lugs and terminals.
Other than the dies, what do you think of the rest of the tool?
Any thoughts on making dies, or modifying the supplied dies?
Thanks,
jv
Jviss,
1/0 is 1/0, is 1/0 under the AWG (American Wire Gauge) standards. The largest dies are labeled as 1/0 for AWG.
I also used the thinnest walled 1/0 lugs I know of. They are commonly referred to as "starter lugs".. A 1/0
heavy duty lug will not even fit between the 1/0 dies with them fully opened.
I am at a loss as to how it is even possible to get a 1/0 lug & wire from ANY manufacturer, that uses the AWG standards, to crimp properly in that tool.
It took four sizes smaller, than the dies are marked for, in wire/lug combination, to make a crimp that is considered a decent crimp. The 1/0 AWG die makes a decent crimp on 4GA wire using a thin-walled starter lug.. This is a LONG WAY from 1/0... Heck the 1/0 die is multiples smaller than just 1/0 bare wire..
Also, can you get me some 7 AWG wire..?
When you mark a tool for 1/0
AWG don't you feel it should at least crimp 1/0 wire and lugs....? It is not marked for SAE wire or MCM or any other standard, it is marked AWG...
Getting into custom dies is going to cost you more than simply buying a tool that works as it is labeled for such as the Greenlee, FTZ or Quick Cable tools........
