butly tape
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
How does one procure some? I don't see it in the store. Maybe I should look when not enjoying some wine.....but any help is appeciated...Tnx
Jun 9, 2013
28
Rafiki 37 Novato, California
He's apparently on vacation until August 19th. That's why the blog at SailNet started. Sailrite appears to be the only other quality source.
Use the link I left and read the blog at SailNet. It has a lot of good information.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
If you need it real quick you will find it in a well-stocked RV/Camper parts store, like at an RV dealer. Down side is it's probably black. I got beige from Palamino, when I was repairing my camper, and got about 10' of 1" wide stuff real cheap.
If you're ordering I recommend MaineSail, but I can't figure out how to order it from his photo site.
Jun 17, 2007
402
MacGregor Mac26S Victoria Tx
For the OP, the RV stuff is slightly different than the stuff Maine Sail has. Thickness, width, "stretchability" etc.
jviss
Feb 5, 2004
7,089
Based on what? The stuff I've purchased looks pretty much the same as what Maine sells, judging by the pics.
I don't know what you got, but Maine Sail explains how he spent a LOT of time finding the right stuff.
Your boat, your choice.
jviss
Feb 5, 2004
7,089
So, you're saying that somehow what I turned up for butyl tape, knowing nothing about it, is inferior to what Mainsail cam up with, because it took him a lot of time to find it. And it's my boat, so I'm entitled to apply inferior materials to it. O.K., got it, thanks Stu. Very helpful.
Maine Sail's butyl tape
No, please chill. All I said was I didn't know what you got, but before I ordered Maine Sail's stuff I read what he wrote and appreciated the fact that he did my "homework" and research for me and found a good product.
I've used it and I trust it and him.
I simply hope that what you got is equal or superior to it, and wish you all the best in the work you are using it for.
All the best, Stu
arf145
Nov 4, 2010
496
Beneteau 331 Deale, MD
I've used butyl purchased at an RV place and from MaineSail. They look the same and both are gray. They are different though. My RV stuff is more like putty--MS's is more like maleable rubber, like Silly Putty. If I pull on a piece of my RV stuff, it will stretch a bit and then break. If I do the same with MS's, it stretches a lot more. Not scientific, but those are my observations.
Feb 17, 2006
5,274
Well, I think Maine will be back in a couple of days. I am sure he will elaborate on the butyl tape he has tested and recommends. I, like Stu, have come to trust what Maine does. He goes beyond what testing is needed to ensure that if he says something he can stick to his guns.
So, let's wait for Maine to get back and see what comments he has.
Phil Herring
Alien
Mar 25, 1997
4,923
- - Bainbridge Island
jviss, there's a post about this somewhere, please excuse me for being too lazy to search for it right now. Basically, it says that he looked extensively for a tape with certain properties that he believes to be important to boat owners, and that not all tape is the same. He found one he likes, and he sells it.
I trust MS's research and judgement, as many others do, so that's the tape I'd prefer. (Just bought some, in fact.) I think that's about all there is to this. I don't see anyone saying that buying another tape is wrong. If it works for you, it works for you. That's all that matters in the end.
Catalina 30 Mandeville, La.
I work in RF communications and have mountains of black butyl tape. It is very similar to what MS sells, but it is black and stands out more than the gray does. I don't know if it is a pliable as the gray, but is sufficiently so. I've used it on many things, but like I said, the black edge stands out more against a white deck and seems to require a bit more cleanup.
Feb 8, 2009
118
Sabre 34 MK-1 Annapolis, MD
When I first got my boat, I ordered some RV butyl, and bedded a fair number of items. Most ended up leaking, and there aren't many spots where I haven't had to redo it. Nothing I've bed with Main Sail's stuff has leaked. His stuff has a much different feel and "stick" to it. I'm sure that with enough effort, another source could be found. Maybe even on the first order! But after making one mistake, and now using his -- well, it's a no-brainer.
Jan 25, 2011
2,439
Well, all I wanted was to find out how to get some of Maine's which is why I posted here. And, yeah it was a typo. I didn't even notice it until it was pointed out...Amazing how you can keep reading things the same way.....So, I guess we can afford some time for Maine to takeoff for awhile. Hopefully, he has fair winds and nice wine. Catch him when he gets back
Sep 5, 2007
689
MacGregor 26X Rochester
I bought a couple of rolls of his butyl tape last year, but for the life of me, I can't remember how. :doh: But I'm very satisfied with that stuff, and use it for most things that need bedding.
There may be similar products available, but I went with the recommendations (primarily here), and in go/no-go fashion, it's worked as advertised, is easier to deal with than anything in a tube, and I'm happy, so that's as far as I'll look. I don't even mask around the joints - after it's had a little time to ooze, I just use a razor knife and gently stretch and cut my way around, in one go normally, without touching gel coat with the knife. Wait too long, and it'll bond to the gel coat though, making it harder to do that.
11,721
Mark,
I hope to be able to re-activate my order buttons tonight or tomorrow if cell service holds up. Right now it is not good. Bed-It Tape will resume shipping Monday.... Sorry for not answering more questions but with 1x data, barely, even a response like this takes 20 minutes..
Jan 25, 2011
2,439
Mark,
Maine,
don't worry about it. It's not critical. Have some fun...
