3GM30F Problems
45
Hunter 34 Long Beach, MS
Some of you may remember a thread I started a while back on my H34 3GM...
http://forums.hunter.sailboatowners.com/showthread.php?t=129163
Well, I completely rebuilt that one with about $2k in parts alone. Every thing that could be replaced was. Once it was all back together awaiting being dropped back into the boat, it was stolen. :eek:
Yep, stolen right out of a shed of my parents' sometime before Thanksgiving last year. (we got the call from the police Thanksgiving afternoon!)
Fast forward to today, I was able to find a local 3GM30F that I picked up for $900. It was from a marine salvage guy so the condition was unknown, only thing he said was it would crank but ran very rough.
I put a new starter, had all three injectors rebuilt and other random missing doodads.
I finally got a chance to try to get it cranked today. First issue was the electronics, I think the main switch on the panel is no good. Using a starter push button switch we were finally able to get it to turn over.
The engine will not turn over without having the decompression levers open. I'm not sure if that's a power connection issue, a valve issue, or a timing problem? I'm going to build some temporary battery terminals for troubleshooting instead of the jumper cables we're using.
I'm able to get it started by opening all the levers, spinning it, then closing them one by one. Closing #2 first seems to be the best every time.
Once it does get going it is running very rough and smokey. I'm not sure where to go from here as I don't really know the symptoms that lead to this state.
I do know 2 of the three injectors were totally bad and the third was on its way out. So, I'm contemplating pulling the injection pump to have it tested/rebuilt.
Only other idea would be to just go ahead and pull the head to have it rebuilt.
I put a couple of videos on youtube of it running so that may help with any advice!
http://youtu.be/oS01KBOjK0c
http://www.youtube.com/watch?v=7tBB-oyIvxU&feature=share&list=UU4rKWOguIdzujanL_-iKDiA
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
For a minute I thought you were going to say you bought it back your motor from the pawn shop:evil:..... I hope home owners insurance covered your loss?
BTW...The only video that would play for me was about a hurricane. Running Windows 8
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
Looks like white smoke which can be an indication of unburned fuel.
The unburned fuel condition can be caused by insufficient compression pressure (do a pressure test of each cylinder) or injection timing may be off (check timing).
Another condition that can cause white smoke is coolent leaking into the combustion chamber.
Good Luck
May 7, 2011
45
Thanks for the quick replies!!
I got the battery issue straight and it fires off QUICK now! :dance:
It starts with the levers in compression mode.
I think we also determined it isn't firing on Cylinder #1. Once running (rough) I put the levers one by one into decompression #2&3 had an obvious effect while #1 just made a rattle. I loosened the fuel line going to the injector, also no effect.
I'm thinking it's a stuck valve, since there was a decent amount of fuel pumping out of the fuel line.
Nov 6, 2006
10,257
Really bad luck !
Could hear on the video that it is running on 2 cylinders.. Start with the injector.. just because it was rebuilt doesn't mean that there is not something wrong with it now..It looks like a lot of fuel may be getting into #1 but not burning. You are probably correct with the valve diagnosis .. you can see an issue if you pull the cover off..and watch as you slowly roll the engine over. other than that and the possibility of a cracked head or blown head gasket, I wouldn't know.. A compression check is probably in order .. sorry to hear that your rebuilt was stolen.. Ya might want to report the serial number to Laborde in the event someone tries to buy parts..
May 7, 2011
45
Hey Claude! Glad to see you pop in! I reported the serial # and block # to anyone that would listen or answer the phone! Police, junk yards, random people on craigslist, pawn shops, the mail man. Well, maybe not the mail man...
I pulled the valve cover and was able to work each valve. They seem to be fine. (After loosing the push rod off the rocker and freaking out a bit!)
I ran it again and cracked the fuel line to the #1 cylinder again, I had thought it may be a bad rebuilt injector. It seems like there's not as much fuel as there should be coming out and it's quite foamy/ mostly bubbles. I've never actually had a bad injection pump, but I suspect that's the issue. I had the injectors rebuilt over at Test Calibration in Mobile, AL and have always had a good experience with them.
Looks like I'll need to buy a factory service manual, then pull the IP. I don't feel comfortable doing it without a little insight first.
I sure do enjoy working on this thing in the garage rather than upside down, squeezed tight, while pitching and rolling!!
May 7, 2011
45
Did some digging on the 'net and found a PDF service manual.
It seems pretty involved to set the injection timing on these cam driven pumps. Sounds like it's set with shims on each injection plunger within the injection pump?
Wondering if I should go ahead and pull the pump to have rebuilt or mess around with the timing? Leaning towards pulling.
Thanks!!
Pat
Apr 27, 2010
970
Correct, raising or lowering the injection pump retards or advances the timining.
I would suggest if you want to do this on your own, get the "Yanmar Diesel Inboard Shop Manual" from Clymer. You can get it on Amazon.com for about $25. It goes into detail on how to adjust the timing.
Good Luck
May 21, 2009
362
Hunter 30 Smithfield, VA
wondered if you've run a compression test yet? Also, might want to swap the #1 injector with one of the others and see if the problem moves with it. A good compression test and an injector swap will confirm what it isn't, and then consider going after the injection pump.
615
Morgan 415 Out Island Rogersville, AL
If you do pull the high-pressure pump to get it rebuilt, you may not have to reshim the pump. I pulled the pump off of my old Onan engine to get rebuilt. City Diesel in Decatur, Al said they didn't think I would have to re-time the pump. I put the pump on using the old shims. The engine runs great and doesn't smoke.
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
You have several indications of low compression that should be checked before going any further, until then everyone is guessing. I would also check the battery, cables and starter connections, make sure the starting system is up to snuff and spinning the engine fast enough.
The injectors can be disassembled and cleaned. You can visually, or with a magnifying glass, determine worn injector parts to a great enough degree you wont notice running performance problems. You can check spray pattern by turning the injectors away and cranking the engine. Most diesel shops or places that sell tractors can test the injectors after you clean them, to check break pressure and leakage.
In the following order... Check starting system. Check valve clearance. Compression check. While injectors are out, service them. Check pump timing. If compression is good and injectors pass muster, and after all checks are made problems continue, then, and only then look into the injection pump.
May 7, 2011
45
Starting issue was solved with a good battery connection. I've already put a new yanmar starter, no Chinese junk.
The injectors have been completely rebuilt professionally. 2 out of 3 were completely bad and the third on it way out. That's what's leading me to the IP. Thinking whatever tore up the injectors also of course went through the IP. The engine is reported to have 200hrs on it. It looks brand new with minimal corrosion. Under the valve cover looks immaculate.
What's the best way to rig up a compression tester? I've got pieces of old 3GM injectors that I could possibly use as an adapter. Anyone recommend the cheap harbor freight tester?
May 7, 2011
45
Well, Looks like I do indeed have compression problems. 220; 340; 345 psi.
Next move is to pull the head and have it rebuilt I suppose.
Thanks for all of the advice!
May 27, 2012
1,152
If the engine only has 200 hours, its odd it has such low compression. Obviously you found an adapter for testing compression. If you can rig up a pressure supply and put each cylinder at TDC on compression, you could test for leakage and verify its the head or rings before pulling the head. If its the rings and its really that new of an engine, its possible that running it hard it could restore itself.
May 7, 2011
45
I did adapt an old 3GM injector I had for the HarborFreight Compression tester.
I'll have to give the pressure test a try with some adapters. I'm assuming they should hold the pressure a standard home air compressor could supply (maybe 100 psi?)
If they hold pressure then it's not the rings? If they leak it's likely to be the rings?
Thanks for the suggestions.
May 7, 2011
45
Head is off! Cylinder #3 definitely has problems. Here are some photos
I noticed as I was wiping the piston/cylinder clean that I could push the piston down an eighth to a quarter of an inch. The other 2 would not push down on either up or down stroke.
Any ideas? I'd rather not go into the bottom end, I've never done it.
I'll be bringing the head and injection pump in for a rebuild on Monday.
Thanks again for the help!
795
Hunter 33.5 Elbow, Saskatchwen, Can.
If you can push the piston down. I think you could have a wrist pin problem or connecting rod bearings. Looks like you have it sitting on the ground so not to bad to pull the oil pan. If you pull the pan you can put an oil drain in while it's out.
May 21, 2009
362
Yup, you need to go into the bottom. Pull the pan and pop the bearing cap off for that piston. Mark bolts/nuts/rod for orientation so that everything is reassembled in the exact position it is now. Hopefully the crank isn't damaged. Check rod bearing clearance with micrometer or plastigage. Might be wrist pin. Let us know what you find. Glad you posted pictures.
May 27, 2012
1,152
Woah woah woah. There is no possible way you have 1/4 inch play in the bottom end. First, the rod bearing couldnt offer that much room unless it was not there at all. The wrist pin could have that much, theoretically, but the bottom line is that the engine would have made so much knocking noise they would have heard it clanking a mile away!
Turn the crank by hand until each piston, in turn, is half way in its bore. Now, carefully and slowly rocking the crank right or left without moving the piston will indicate if there is in fact any reasonable play. Note also, the rings will make some noise as the piston reverses direction, often a clicking/snapping sound. But as noted, if the motor is out, just drop the pan and look at the rods and main bearings. NAPA sells "plastiguage", ask for it by that name. Get two or three different sizes. You remove a bearing cap, place the string on the bearing, reinstall the cap and re-torque the bolts. The string is squished flat to a width indicative of bearing clearance. Now remove and read the scale on the paper envelope the string came in. It will indicate oil clearance and is a very good indication of bearing wear as well as taper (wider or narrower across the face of the bearing).
It doesnt look like the tops of the pistons are wet with oil, so it appears it wasnt pumping oil past the rings. I would take a good look at the valves. Plain rubbing alcohol, carefully poured onto the inverted combustion chamber sitting on a bench so as not to spill, you should not see any leakage in the exhaust or intake ports through the valve seat. I am not sure what your seeing on that one piston, regarding play, but you may watch the crankshaft as you push and note if it turns. There should be minimal play at best. But if its out of the boat, now is the time to make it right, whatever that entails.
Apr 27, 2010
970
Just an observation, What are those marks on the top of the piston head. They look like marks or stains caused by the Valves. These marks are absent on the other cylinders. Do you have photos of the heads?
