Ok its been gone over but upgrading / rebuilding our 1982 Cat, wanted to pull the spreaders and of course could not get bolt out 31 years can do this aluminum and stainless steel do funny things, some have found out.
not sure Id try this in a bosun chair!
Cut the head off the one end bolt side was my failure side so I just pried up spreader bracket a bit and used a hand saw, And leave nut or vise grip on other side.
Next clean the nut side out a small dremel tool bit would of been sweet ! bushing compresses the aluminum mast and sort of flares hole so no way you can get froze bolt and bushing out till you clean it out good luck!
