Got a "sideways" picture, too? That'd help a lot.thanks stu here is a pic of the old and the new........they checked out the same on the binch....
regards
woody
regards
woody
here ya go stuGot a "sideways" picture, too? That'd help a lot.
if you look close you can see that the one is sitting on a different plane than the other one in the two differnt pics...So, it looks like the new one is longer but has a tighter angle, which should be the same "target" into the hull. Am I reading this right?
and that is what got me to looking at angles in the first place.... i pulled the dip stick out and a little oil came out of the dip stick hole....i pumped out the oil and also found that i had 3/4 of a qt too much in the crank case... so now before i change any thing else i am going to put the proper amount in there and see what happens.... even to taking the breather tube off the intake and looking for oil to come out..... because if it is to much angle it will act like a blender if the crank shaft is churning the crank case oil and cause it to foam and i don't want to go through a runaway engine because i have oil going it the cylinders ....if the problem is there i will just have to reset the strut and rework the shaft tub like you did....Woody
It sure looks like a 15 degree strut like mine as doing the max angle is pretty common when the motor is that far back in the boat under the steps
I can only use 3 quarts of oil because it's maxed out but as it 43 years old it must be OK![]()
no they are both the same in relation to angle of the coupling to shaft ...i checked on this yesterday and found out that they were available on the larger engines back in there hay day.....no so common on the smaller onesYou never answered one of the early questions. It was pointed out that some drives have an offset/angle drive transmission. Is it possible your old drive had an angle drive and the new one doesnt? Could you get one?
If I were going to drill a new hole, I would try to align the prop shaft to the motor rather than the other way round, within reason. Even if that meant a different cutlass bearing. While some of these lil motors have survived high angles with short oil capacity, thats not optimal. I would prefer to see the engine at as low of an angle (close to level) as possible. If you ever went offshore and needed the engine, you might really appreciate the extra oil capacity as well as being able to keep it contained.
.....i could have a custom one made....but i think my best solution is to get it as level as i can ....because in ll this i think the main bearings and the clutch would suffer and ware sooner than later as most of the bearings are babbitt and not ball or roller ...and i am not sure how much side thrust they could handle...i even though about an external oil reserve.....This may be a dumb question, but are there aftermarket oil pans for these engines? I buy larger (500-800 hp) diesels for industrial applications on a regular basis, and there are usually options for different oil pans - sump forward, sump aft, larger/smaller capacities, etc. Any chance of a deep sump and pickup tube extension or longer replacement (dipstick, too)?
No disagreement from me. I'm just tossing it out there as a last resort, in case you're stuck with a bad, or even good-not-great, installation......i could have a custom one made....but i think my best solution is to get it as level as i can ....
thanks for the concern that is a nice thing to give some one.....and like i said it is an option but me being as hard headed as i amNo disagreement from me. I'm just tossing it out there as a last resort, in case you're stuck with a bad, or even good-not-great, installation.
OK i have taken the strut back off and removed all the shim work....i have also taken the engine back out of the bay and will be putting things back on Tuesday next week as i have run out of time this week .....gotta make a trip to fair hope and help my buddy do a turn over on his boat he sold it this week so i will be gone all weekend and Monday and this trip is killing me because i would rather be working on my boat lol...so when i get back i will set things up and see what gives....my concern is that when i bolt the strut to the hull it will be out of alignment to the stern tube and i have to see if it will work without rubbing the prop shaft iUnless the tube is REALLY BAD it should be fine
Rememberer my tube was FULL OF BLISTERS or i could have most likely made it work
From what you have said about having to add shims something is clearly different
As it worked without issue all this time i have to believe you just need understand what is different about the strut ,as struts are NEVER exactly the same
Some pictures of this would help me understand whats going on as its tough to see it right now
I would remove the rubber cutlass bearing if possible and replace it temporally with bronze bushings as it removes all the guess work
You may have to grind metal off the strut OR fiberglass off the hull to get things in a reasonable position
Just be real sure before you do this as it comes off pretty essy and is real hard to put back on
I understand what your saying, but only to a point. A 15 degree offset angle drive transmission would put this motor at 1.5 degrees from level just the way its set up now. A lil fiddling with that cutlass bearing and he might be able to widdle that 1.5 down even further.On a 30' boat with the motor that far back is not possible to have a more level motor
If you look at other boats and scratch your head as to why they would install the motor under the kitchen sink?
It’s under the sink because it allows much more level install![]()
