Your solutions to sea water odors in toilet intake?
Dec 2, 1997
8,975
- - LIttle Rock
(reposted in "ask all sailors")
Have any of you installed a separate water tank to supply fresh water to flush a sea water toilet? Do you add any "deodorizing" or other products to the tank...if so, what? Can you provide a photograph of the installation that includes the plumbing?
If you've re-routed your head intake line to tee into the head sink drain line, can you provide a photograph that shows exactly how you've done it?
Have any of you cobbled up a "one off" reservoir (NOT the Raritan Crown Head reservoir or Flush Water Kit) installed in the flush water supply line on a sea water toilet that you fill with some type of deodorizing or mineral dissolving product ? If so, can you provide a list of the materials you used, your "instructions" for use, and the chemical used...and a photograph?
If you've installed any of these, or can send me to someone who has, I will be very grateful!
I have a very specific need for examples of ONLY these three types of installations, and I'm on a tight deadline, so any help will be appreciated!
Thanks!
Hunter 37 C sloop Punta Gorda FL
(reposted in "ask all sailors") Have any of you installed a separate water tank to supply fresh water to flush a sea water toilet? Do you add any "deodorizing" or other products to the tank...if so, what? Can you provide a photograph of the installation that includes the plumbing? If you've re-routed your head intake line to tee into the head sink drain line, can you provide a photograph that shows exactly how you've done it? Have any of you cobbled up a "one off" reservoir (NOT the Raritan Crown Head reservoir or Flush Water Kit) installed in the flush water supply line on a sea water toilet that you fill with some type of deodorizing or mineral dissolving product ? If so, can you provide a list of the materials you used, your "instructions" for use, and the chemical used...and a photograph? If you've installed any of these, or can send me to someone who has, I will be very grateful! I have a very specific need for examples of ONLY these three types of installations, and I'm on a tight deadline, so any help will be appreciated! Thanks!
Peggy, we use a gallon jug of potable water. Pour it in bowl as needed.
(reposted in "ask all sailors") Have any of you installed a separate water tank to supply fresh water to flush a sea water toilet? Do you add any "deodorizing" or other products to the tank...if so, what? Can you provide a photograph of the installation that includes the plumbing? If you've re-routed your head intake line to tee into the head sink drain line, can you provide a photograph that shows exactly how you've done it? Have any of you cobbled up a "one off" reservoir (NOT the Raritan Crown Head reservoir or Flush Water Kit) installed in the flush water supply line on a sea water toilet that you fill with some type of deodorizing or mineral dissolving product ? If so, can you provide a list of the materials you used, your "instructions" for use, and the chemical used...and a photograph? If you've installed any of these, or can send me to someone who has, I will be very grateful! I have a very specific need for examples of ONLY these three types of installations, and I'm on a tight deadline, so any help will be appreciated! Thanks![/QUOTE
Peggy, We use a gallon jug of potable water as required. No additives, no sea water.
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Flush tank on a Hunter 410
Peggy: Attached is the only photo I have readily available of the temporary version of the fresh water tank I installed on my Hunter 410. The boat is on the hard an hour away. The black valve at the bottom of the photo is plumbed into the head intake line. Thus, there is no need to open the intake through hull to use and flush the head. The tank is filled from the shower spray handle. I have since built a starboard box and enclosed the bag tank where it is now. The top of the tank is useable for storage of towels, etc. and the fill fitting pokes out the top as well.
Post edited to add a second picture showing fill fitting.
6,243
S2 9.2a Fairhope Al
thank you Peggy...yes i ill be more than glad to...i didn't write any info about the install as i felt that YOU having recommended this arrangement would know exactly what or how to describe it.....if you have any questions please feel free to ask....
regards
woody
P S Peggy..plz.. send me an email to woodster3046@yahoo.com ...i am not sure how to email you theses through this site .......
8,975
- - LIttle Rock
That's just the kind of thing I was looking for, Mulf. If you can email those to me, and--next time you're on the boat--take a couple in vertical orientation that show the connection to the toilet intake too!
Emailing me is easy: just click on my name to the left of this post, then select email. Don't worry about attaching photos to that one. Attach 'em to your reply to my reply. And thanks!
Dec 2, 1997
8,975
- - LIttle Rock
You're right, I don't need that explained to me! :)
regards
woody
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
not sure this is going to work Peggy but here goes....
6,243
S2 9.2a Fairhope Al
:confused: not sure this went through there is no place on sending you an email to copy and paste the reply...not enough nuts and bolts....
regards
woody
