BEFORE I get blasted, YES, I know there are a hundred threads available with information on dealing with a leaky mast -- however, I want to make sure I am NOT solving one problem, by creating a new, possibly larger problem.
On my relatively new to me Oday 28, our mast seems to be allowing water to travel down into the bilge, a nuisance. Generally not a lot of water, but here in FL, we have had our fair share of intense downpours, generating 7+ inches of rain.
My bilge pump works fine, and we are talking about a couple of pints of water, with an average storm. You can see minor remnants of water around the cabin top, where the mast comes through, as shown in the image.
There is no mast boot, just Gorilla tape at the base of the mast, with some silicone in the mast slots.
If you look up into the mast hole, what seems like old foam, with a bit missing is visible, see image ---
a few other threads suggested "filling and sealing", Stu Jackson mentioned using silicone and old line,,
I WANT TO MAKE SURE, on our Odays, that if I STUFF the mast as it enters the cabin, is the cabin top sealed around the mast?,
or will the water permeate the cabin top, and cause some rot issues,,,
I just want to be 100% clear!!
as always, thanks, and Happy Holidays,
cheers,
Coyote
cheers,
Coyote
