snow job
Hello,In think you are being snowed. When the engine is running, the temperature inside the combustion chamber is over 1000 degrees F. Any liquid is instantly vaporized. Contaminated fuel will result in increased emmissions because it won't burn, but as long as the engine is running there won't be any liquid in the cylinder.If the engine never ran, and you tried starting it when raw fuel or water was in the combustion chamber, that could cause the problem your mechanic described. However, when the engine is running it's way too hot for liquid to be in the cylinder.good luck,Barry
