Yanmar starter solonoid
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
My 3QM has a bad starter solenoid. Yanmar calls it a magnetic switch. I have found a replacement for $220 which seems awfully high to me. I am looking for those of you who have ordered similar Yanmar parts. Is this the going rate?
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
Are you sure it's a bad solenoid? If you don't have full voltage from the control panel, your small voltage loss might be the issue. A simple, cheap relay might solve the problem.
higgs
Aug 24, 2005
3,738
I am sure it is the solonoid. Replaced the wire with 10 g from the start switch. Tap on the solonoid with a wrench and it works. Otherwise no.
SG
Feb 11, 2017
1,670
Try a 16 gauge wire directly from the battery to the solenoid. If it works fine, let me know. It may not be the gauge. I also just replaced a 19 year old key switch.
capta
Jun 4, 2009
5,100
For $220 you should be able to get a rebuilt, if not new starter. Personally, I'd take it to a starter and alternator rebuild shop in your area and have them check it out. If it is the solenoid, I'm guessing they can replace it for under $40.00 all in.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
What Capta says. A good reputable rebuild shop is worth its weight gold. You can tell a reputable shop from the size of component piles vs size of piles of whole parts. Also his bench will have a good drive system with old crusty knife switches and fifty yr old 10” analog Weston parallax corrected volt and ammeters. I told my guy i want his bench when he hangs it up..
Jun 15, 2012
719
BAVARIA C57 Greenport, NY
Over a year ago had same problem with solenoid on Yanmar diesel in my generator. Replaced with Chinese made starter from Amazon, around $65.00 with shipping. So far works perfectly.
May 7, 2012
1,625
Hunter e33 Maple Bay, BC
A quick email to this vendor should confirm if this will do the trick. The 3QM parts manual agrees with the Yanamr p/n in the link. Maybe worth a try for the price of the ticket.
https://www.amazon.com/Starter-Sole...D=419U5J%2BbcLL&preST=_SY300_QL70_&dpSrc=srch
rfrye1
Jun 15, 2004
589
Hunter H376 San Diego
I wired the Relay (found on this forum) because of starter issues on my Hunter 376 (Yanmar 3JH). No issues since..
good luck. Bob
Jul 1, 2010
990
Catalina 350 Port Huron
+1 on finding a good rebuild shop. I had my Yanmar starter rebuilt last winter (due to a bendix problem...would spin but not engage at times). I think it cost me $130, and they also put on a new solenoid. I'd rather have the Yanmar unit fixed than go for a cheap starter online. $220 doesn't surprise me at all for a Yanmar solenoid. Yanmar parts are getting pretty pricey. FWIW, I also added the relay for the start switch wire.
May 24, 2004
7,228
CC 30 South Florida
Not surprised at the Yanmar cost. Find a generic replacement or find the tractor equivalent part. Capta's advise is on point, take it to a starter/alternator shop and they will find one and refurbish the starter for under $100.
higgs
Aug 24, 2005
3,738
https://www.amazon.com/Starter-Solenoid-S114-303-S114-303A-HITACHI/dp/B079H3GWH6/ref=sr_1_2?m=A34668PDYO45KB&s=merchant-items&ie=UTF8&qid=1529938948&sr=1-2&keywords=128170-77010&dpID=419U5J%2BbcLL&preST=_SY300_QL70_&dpSrc=srch
Thanks for taking the time to send me this link. Today I found out that the part Yanmar matches with the 3QM is not the same as the solonoid I pulled. The yoke attached to the solonoid's cylinder is T shaped, not slotted like the one in this link.
