Much discussion about this over the years. Lots of opinions, but IMHO, as long as your engine reaches operating temperature at whatever RPM you choose to cruise, that should keep everything in good working order.
The question is how can you tell whether your engine is running at the appropriate temperature when most engine panels only have idiot lights?
If a prop is under pitched it will reach the specified RPM but still be wrong. You want to be able to reach max rpm or close to it but the engine should have to work to hit those last few hundred RPM. If it just zooms up to full RPM it's underpitched.Prop pitch is determined by the ability of the engine to reach it's specified maximum RPM.
It's not uncommon for builders to just slap a prop on there and have it be wrong. My previous boat, a Catalina 30, had a significantly under pitched 2 blade for the particular engine in that boat. I took it to a prop shop, they added pitch to it, and the performance improved substantially.wounder whyPO had it pitched the way it is.... Pardon my ignorance on the subject of prop pitch
Also something to watch is that older (20+ years) yanmar's tend to be off. My yanmar 3GM's tach shows 2000 rpm when it is actually 2600 rpm.
That's the ticket! I keep one on my boat and occasionally use it to compare to. my tach,it is within a 100 rpm, close enough for me!or check it with a portable, non-contact tachometer. They are not expensive.
it actually just marks the rpms as the flywheel makes a round not really counting ....this is accomplished by the break in the electric signal as the gap on the flywheel passes by the proximity switch on the bell housingYanmar uses a sensor that I believe counts the revolutions of the fly wheel.
If the prop is correctly sized and pitched every Yanmar should be able to attain 100% of max rated RPM. Sadly far too many boats are under or over propped..All boats with identical engines are not the same. Also depends on your prop / pitch.
