I'm putting together a spares kit for my Yanmar 4JH80 engines on my Knysna 550 catamaran. This is above and beyond the normal consumables.
What I have so far is:
I have a PDF of the service manual for the 4JHE/TE. Does that cover the 4JH80?
Similarly, I have the Parts Manual for the 4JH. Does that cover the 80 version?
Any suggestions would be appreciated.
- Raw water pump & gasket
- Thermostats & gaskets
- 1 set of injectors
- Heat exchanger/lub oil o-rings
- Radiator cap
- Do I need Fuel Injector lines? I seem to remember seeing a sticker on the engine stating that they should be replaced with the injectors.
