Yanmar 2QM15 Please help
113
Hunter 34 Tilghman Island, Md
With my 3GM the answer for cold starts on the Chesapeake bay has been to give it plenty of throttle. Same for the boat I used to race on. Remember you can't flood a diesel. Just be ready to throttle back as soon as it turns over.
arf145
Nov 4, 2010
497
Beneteau 331 Deale, MD
Same for my 2GM.
Dec 4, 2005
27
1984 Hunter 31 Geneva Ohio
Same problem on my 2gm and a friends 2GM both problems were the lift pump. It would leak back enough to loose prime and was hard to start, new lift pumb fixed both boats
Dec 1, 2008
16
islandpacket 31 virginia
I did read somewere recently that yanmar had a service notice about a fix for this on certain engines. Sorry I dont remember the exact. But will try to search it out and post. But there is some offical info out there
Oct 26, 2012
8
Watkins 27 Sloop Baltimore
thanks again for all the great advice all... it sounds like it might be worth it to have the injectors and timing looked at, it is 31 years old. IT started today at 55 degrees but it does seem to lose prime when sitting. Im going to try something to preheat it. Since i wont have power on the water to use a hairdryer im thinking of putting those toe warmers things that chemically create heat on the injection chamber. Even if it just heats it from 50 to 70 im wondering if that makes a difference. Will advise if this trick works, i know cold starting issues is a common problem.
