Xantrex 1800 just died, do I get similar or cheap generic inverter?
Nov 12, 2024
2
Morgan Morgan 43 North Point
My Xantrex 1800 inverter just smoked and died. It has been in my Morgan 43 since 2007. 18 years is a good run for an inverter. I could get a replacement new unit for $1,700 which would make installation easy, but it would be 25 year old tech and less efficient than newer units. I could get a used one for $500, or a new "Amazon recommmended" 2KW, surge to 4KW generic unit for $200-300, with remote display. There is also a new design Xantex 3KW marine unit for $1,200 which charges LiFE batteries I will be installing, but it is huge and I would have to rearrange a lot of things to make room for it, so not very interested. The $200 2KW unit will probably be less reliable, but for some Bahamas cruising planned next year and E. Carib cruising planned the following year, I could carry a spare and still save a lot of money. Having a spare seems even better reliabilty unless these generic units fry often. But I don't have any experience with these $200-300 generic inverters on a boat. Opinions? On my boat, the inverter is only about comfort as there is no navigation, life or boat safety equipment on the inverter.
I don't want to quote or mis-quote our resident electrical guru but I think the body of his work would suggest to not buy cheap crap. Other than that I don't know what he would say. But it would be interesting.
I would do the simple thing and buy the drop in replacement- that is my rule. 18 years is good service and if it met you needs for that time why take a flyer.
I guess the fly in the ointment is the LIFE batteries. Those may cause you to re-evaluate the whole design of your electrical system including charge sources. That may call into question the role of your inverter.
So I'd say knowing where you want to go should lead to a game plan to get there. Now seems like a good time to make that plan.
With regard to inexpensive chargers, I have found them to be very unreliable. I know you are talking about inverters, but the solid state chargers (And inverters) common in the chandleries fail often. Maybe with any bolt of lightning nearby. Or power surge. But I've replaced so many on different boats, different numbers of batteries, different amps, that I consider them unreliable. When I worked at a chandlery they were one of the most returned items.
For short term use on the way to a better system ... maybe.
Likes: SycloneDriver
capta
Jun 4, 2009
5,006
What makes the $200-$300 unit so inexpensive is that most likely it is not a pure sine wave inverter. That's fine if you have electrical/electronic equipment aboard that does well enough on the square wave inverter, or you just prefer the pure sine wave.
Also, I believe that your Xantrex is a charger/inverter, which the inexpensive ones are not.
My 3k square wave inverter did just fine for me, on a Caribbean charter boat, utilizing what electric tools the cook needed to create meals, such as an air fryer, food processor, microwave, etc. Our computers also did not seem to mind.
  • Helpful
There are very few places on a boat where cheaper is better. The up front costs may be lower, but reliability and safety are important.
@shemandr's comments about a long term electrical plan are worth heeding. A well thought out plan will leave you with a safe, reliable, and efficient system.
colemj
Jul 13, 2004
813
You should clarify if you are looking for an inverter/charger, or just an inverter. The cheap inverters on Amazon are pure sine wave, as this has become inexpensive to produce nowadays. However, they are inverter-only, and have no charging function. I know many people with them, and observationally it seems to me that the ones that fail do so pretty quickly (usually within the 1yr warranty), while those that don't fail quickly run for a long time. The failure rate hasn't seemed to be high, but this is all guesses from observing from a distance.
We carry a spare one of these cheap ones (3kW $250) in case our Victron Multiplus goes. However, I don't expect it to do the same functions - just get us through until we can get another Multiplus. We use our inverter to run A/C, dive tank compressor, water heater, 120V HO watermaker, and other heavy loads, and I have no confidence one of these cheaper units would handle this full-time.
If we were to coastal cruise with lighter use, I would definitely consider this as a primary, and carry a second one for backup. Maybe not even that, since I could just order another from Amazon and have it in my hands the next day pretty much anywhere I was.
If you rely heavily on your inverter, or need an inverter/charger, then you should consider spending money for better established brands/units. If you only use it to charge computers, run a TV, and other lighter and temporary things, then one of these cheaper units might be good value.
FWIW, I've bought two Victron Multiplus units over the years, and each time the first units shipped were DOA. So spending more doesn't necessarily mean high initial quality. However, Victron (well, their dealers) respond immediately and make things right.
Mark
Nov 12, 2024
2
So with the October Amazon Prime Days this week, I ended up buying a Zetawale 2,500 W pure sine wave inverter with ATS for $183. It has the same size and connectors locations, so it will be a drop in. I have done some testing and its idle power drain is essential zero and the efficiency when running at over half capacity to power my biggest-model Brevelle toaster/airfry/convection oven (1,600W) is around 80% (Using the BMS power draw from the LiFe Bluetooth battery app. so may not be accurate.) The automatic Transfer Switch is a relay, rather than a sine wave phase match electrical cirucuit, so that could trigger a reboot on future internet routers. The remote has on/off and a light on/off swich, which is better than many $1k inverters. The sine wave looks good on the scope, but I didn't study its response to different loads. So far, looks like a good decision.
People made the point than an integrated charger/inverter that can charge my future LiFe batteries might be a better choice. I did find that the 150 Ah chargers in the $1,500 Xantrex integrated units looks better than the biggest stand alone charger I found at about 80 Ah. The reliability reviews from the Zetawale inverter, which is bought by the tousands every month by construction workers and other daily users were good. But the reviews on the high capacaity LiFe stand alones were not that good. (the volume purchasers of the Inverters are putting them on vehicle charging systems.)
Another thing I noted in my research is that the typical LiFe batteries we are using have a BMS limit of 4 batteries in series, so that limits the max size of a single bank to 4x whatever battery you are buying. Zantrex has a 48v integrated system which has a DC/DC converter for powering your 12V devices. At 48V, you can build a 4S4P battery bank, or 16 times the power of whatever battery you are using and build a massive LiFe battery bank. But the 660 Ah LiFe bank I recently bought the batteries for seems like plenty for my solar/wind/engine charging capacity. I'm an island hopper, hot a Pacific crosser.
colemj
Jul 13, 2004
813
Is the limit four batteries in series or four batteries in parallel? I understand the series limit, but parallel really shouldn't have a limit, or at least not that low.
If the limit is only for series, then that only affects voltage, and few are going to go above 48V. If there is no limit to parallel, then the bank can be made whatever size is needed from whatever batteries you buy.
Mark
