woodwork
ted
has anyone any experience in using trex for steps, etc. on sailboats. i am thinking of putting it on the rungs of the boarding ladder on the stern of our 26.5 hunter. other applications cross the mind such cockpit flooring, in outside storage compartments in the cockpit, etc. i understand it can be used as wood, stained - also considerably cheaper, etc., etc. perhaps also will help to save some of the rain forests!
L
LaDonna Bubak - Catalina Owners
What's trex?
Never heard of it. Can you post a related link? LaDonna
ted
trex
trex, i hope i have got the name correct!, is found in the lumber departments of home depot - among others. current main usesis for the building of such as decks on the sides of houses. comes in gray or light brown colors and can be used, cut, sawn, etc like regular wood. stained apparently also. comes in lengths of up to about 20 feet, rounded on two edges. much cheaper than most regular timber used for outside work and longer lasting. first tentative impressions are that the days of only being to use impregnated timber for outside/semi-outside projects could be towards the end. there is another similar product whosename i cannot immediately recall that is sold in up-to-date lumber yards. home depot seems the best first port of call. as i initially mentioned in my first message, i think it may be a cheaper and in everyway more satisfactory for boarding ladders, cockpit lockers, etc. where water - including that which is saline - is prevalent from immersion, wet ropes, covers, wet foul weather gear, the crew's wet bikini, or 'is minimal covering - after all this is all about the art of sailing! ted.
G
georgelakesiii@yahoo.com
Positive use
Made a deck with Trex over 2 years ago and could not be happier. Also available in lengths of 12 feet. Comes brown and turns grey in a few months which can be accelerated by harsh environment. Never need to paint or worry about termites I suspect. Weighs about twice the weight of redwood but needs more support. Must have 12inch instead of 15 inch centers so wherever it is used it should have good support if high lb/ft application. Don't know how it will stand up to salt water, but expect it will do fine as it is a plastic wood composite. They also make it in a railing application which I suspect will be stronger and better for any application of higher load baring requirement. I find it looks great in a natural finish. The deck I used it on is in the channel backyard .
