Wiring
Oct 30, 2019
234
Tom (And others)
Whenever you are replacing - or installing new - wiring, I strongly
encourage you to use "marine specific" wiring. It will be tin-plated copper.
The tin plating significantly helps prevent corrosion at any - and all -
connections, as well as the copper wire disintegrating over time in a
salt-air environment.
Yes, it does cost a bit more, but it is well worth the difference when it
comes to future problems.
Good Luck on your endeavors.............................Ed[Non-text portions of this message have been removed]
olavhm
Oct 30, 2019
49
There are som pictures of the Vega wiring system under the "files" folder, but, the scanned
documents are not enlarged sufficiently for the text to show. Does anyone have the original
and the possibillity to enlarge and scan it again? If so I would be very thankful. I can be
reached at olavhm@....
Olav Vega#1480
Nov 13, 2006
5
Hi Olav
if someone could get better quality scans of these drawings to me - I
can redraw on AutoCAD & pdf format and post for all to use.
thanks
John
Lyra V1364
