Bob
I purchased a Guest 10 amp charger that came already wired (two battery wires and main AC 3-prong plug in). I want to place a breaker on the panel (15 amp) and wire the breaker to the AC system and the plug wires to the breaker. Okay, I have a recessive gene in electronics and do not have a clue as to where to start! I have an 1988 C-30 model with updated panel. When I open the panel I see a bar that has the white, black and green AC wires coming in from the deck fitting and out to the interior AC outlets as well as to the AC main and water heater. Simple enough! So, how many fittings will my not yet purchased breaker have on the back, two or three? How and where do I attach the three wires from the charger to the breaker and the breaker to that AC bar? Or is it visa-versa? Its probably very simple I am sure, but, I need to be right on here. Can anyone walk me thru this process a step at a time?ThanksBob
