winterizing
2
hunter 23' lucasville
hello everybody, i am a newby (1st time buyer). i just bought a 1985 23' hunter & would appreciate any advice on preparing it for winter (drydock).
Jun 30, 2004
446
Hunter 340 St Andrews Bay
Before we reinvent the sail, have you used the search tab to look into the archives. There is a plethora of winterizing items on this website already. After you've done a search, maybe come back and ask some specific questions.
Of course this brings up an interesting idea-maybe there should be a "Winterizing" tab in the resource library. I took a quick look but didn't see anything.
Oct 17, 2009
2
have tried search; nothing specific, most advice is for bigger boats. mine hasn't been in the water for a couple yrs. also the sink has been disconnected due to lake regs.
Jun 30, 2004
446
Outboard I suppose? Follow OB directions.
Porta potty? Take home and put in garage
Do you have any thru-hull valves?
Drydocking like that you should have it pretty easy. Drain drain again and wet vac all you can.
If it moves and shouldn't use duct tape; if it doesn't move and should use WD-40; and if you can't drain it put in pinks stuff!
