Winterizing, blowing out water lines with tire pump.
Nov 17, 2012
86
Hunter 37.5 Cherubini Bayfield, WI
I am just back in to boat ownership after a few (miserable) years away. I seem to remember doing this with success years ago. Any thoughts?
Jan 4, 2006
7,823
As long as it's not a hand bicycle pump :) :naughty: :).
I blew out the lines a few years ago when I spent a winter on the hard. We don't get very cold weather here but I was concerned that I didn't have the ocean below me as a heat sink.
I had installed an air inlet downstream of the tank outlet valve. First let a flow of air pass throught the open lines. Then repeatedly letting the lines pressurize from the compressed air and then snapping open one outlet at a time blew them dusty dry. Finally blew back into the empty tank with the hope that this last bit was clear.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Shop Vac
I have used a shop vac blowing side to do this but a hand pump I don't
think so.
Nick
1,096
CS 30 Toronto
Low point in the loop
If you have a low point in the loop, there will always be some water sitting after the air blow by. Small amount of water will drain back to the lowest point and freeze if it is cold enough. You can never blow all the water out of the lines.
I use an electric air mattress pump to blow out the line and then send some pink antifreeze back into the line and then blow it out again. So if there is any drain back it will be antifreeze.
The idea is to reduce the amount of antifreeze staying in the line.
Feb 10, 2004
4,249
Hunter 40.5 Warwick, RI
I use my dinghy pump. It works fine, but I wish I had an electric pump so I could just connect it and then go to all of the faucets. That would make it a one-man job instead of requiring a second person.
Hunter 29.5 Gloucester, VA
I've used a wet vac on many occasions to remove water from lines.
Dec 19, 2006
5,836
Air
I used air a 12 volt air compressor and larger ones too to blow out my RV and boat all the time up in NY and never added antifreeze.
I did use a shop vac on the plastic water line as it came out of water storage tank and yes let it blow air plenty of time,I tape with duck tape from shop vac onto the water line and let it blow air while I open everything until no water.
Nick
1,096
CS 30 Toronto
You certainly can just blow out the water with air in Florida. Unfortunately, in Canada we have -30C (-22F) in the winter. With wind chill, even antifreeze freezes at some point.
