Winter Prep
361
Hunter 30 Middle River MD
Having a hard time deciding if I should have the boat pulled for the winter or keep her on the water. I am familiar with the prep if we choose to have it pulled but what should be done if its going to winter over a float. Given our normally mild winters, at least compared to upstate NY, it seems like it might be possible to go out at least a few times between end of Nov when I have usually pulled and early April when it has gone back in.
If I leave it on the water the marina will deal with a bubbler if that is necessary but how do I protect my engine the new one is fresh water cooled. I know I can deal with the water and waste systems by drain them and where not possible filling with non toxic antifreeze.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
I've left mine in a few winters and I've found the prep to be almost the same. About the only difference I can think of is that on the hard I leave all my seacocks open, in the water I pour antifreeze through them and then close them. I also find that it gives me an excuse to come down and check on things more frequently :)
5,802
After sailing I would run two gallons of pink stuff through. Just to make sure the strainer, pump, heat exchanger, and muffler are protected.
