Winter In the Water
Apr 14, 2020
8
Beneteau Oceanis Huntington
Hey All
Up here on Long Island. Considering next year to leave the boat in the water during the winter months.
The club has the staff and the gear to maintain
Probably has to haul in the spring to power wash. maybe bottom and wax
It it is a mild winter like this could get a lot use of the boat
Any thoughts on this
Thanks
7,682
Alden 50 Sarasota, Florida
Lots of people stay in during winter for various reasons, however, using a boat which is winterized and covered as it should be isn’t one of the reasons.
I have one friend who leaves his Seafarer in the water year 'round. He doesn't even use bubblers or other ice prevention. You can't imagine how nice it is to go for a sail on a nice day in January - and there are some. Totally different experience than a Summer sail but sometimes even more beautiful. His boat has a round chine so if ice closes in it basically lifts the boat up, and when it melts it lets it back down. He has had incidents when the ice pulled poles out and the floating dock and his boat went for a driftabout. But really no harm done.
Jan 24, 2017
672
Hunter 34 Toms River Nj
make sure that you winterize all thru hull fitting properly, have all zincs checked, and use concentrated non tox anti freeze in the bilge and discharge lines.
Don't want to sink a boat because bilge pump and lines froze up.
Make sure you re winterize the engine after each use, plus use an extra gallon if you can't see exit the exhaust
Apr 5, 2009
3,294
In the Washington costal region, most of us leave our boats in the water all year. I dive the boat 2-3 times a year to clean the bottom and check zincs.
I used to have my C30 in Coeur d' Alene lake in north Idaho and given the cold winter temps and fresh water, the lake would often freeze. Many of the boats did not do anything other than winterize the water systems and the ice would not harm the hulls. I used a 1/3 hp fresh water sump pump to keep my slip open. It was tied with a rope to a deck cleat and the harbor master would plug it in and drop it in the water if we started to get ice. My pump would keep my slip open along with those on each side of me as well as the thoroughfare behind the boat.
619
Tartan 34C Toms River, New Jersey
I leave mine in during the winter. I winterize all systems and the dock has a thermostat controlled bubbler. She is pulled in the spring ( I beat the quarantine this March) power washed, waxed, bottom painted, and splashed.
Jersey winters have been mild the past several years here on the Jersey Shore. But even when they weren't the system I use worked fine.
capta
Jun 4, 2009
5,069
First winter I had this boat, I spent aboard at a marina in East Greenwich, RI. Even if you get one nice day, chances are the docks will still have snow & ice on them and that can be super dangerous & scary.
I also agree that it would be a problem if you winterize or don't, either way.
Are you thinking of leaving the sails on all winter, or taking them on & off for each sail?
Dec 25, 2000
6,052
Winters here mild in comparison to the folks noreast. We keep her in the water year around ready to go at the skipper’s whim. Been out many times during the winter months when anchoring spots are empty and boat traffic nil. It is the time of the year that Wallis gets a real workout and the wonder of being under sail in a snow fall.
May 24, 2004
7,209
CC 30 South Florida
Heck, Winter is when our real sailing season starts here in Florida; our winds are back and the temperatures and humidity are nice.
Oct 26, 2010
2,214
Hunter 40.5 Beaufort, SC
Fall and Spring are the best followed by Winter as still great sailing here too. Summer is hot and humid, with either hurricanes, no winds.
I've always wanted to see snowflakes trace the airflow over the sail plan. It has never worked out.
Yikes!:yikes:
I used to do overnight X-ski backpacking trips when I was younger. Now I don't even like it when it gets down in the 50s.
