Winter Covering
When I had my Catalina 25, I bought four sections of 1 " PVC pipe, and a big farm tarp (the silver & black olds they use to cover hay). Although I dropped my mast, I placed the pipes acroos the boat at each stanchon, and tied them fast ...... this kept the tarp up. I draipped the tarp over the boat, rolled the tarp back and up under the bow and tied it down, up under neath, with rubber bungie cords(and stretch them tite). I also parked the boat, bow into the wind, and left the back open. It allowed the air to flow through and also access to get into the boat, if I wanted. You may have to figure some way of peeking the tarp for water run off though, or elso you will have a tremendious water buildup that will distroy everything. Also, with the mast up, just buyt two smaller tarps, and overlap them around the mast base. Hope this helps. Bob Burns=Rascal May you have smooth sailing on warm breezes !
