Catalina Direct's approach
Talked with Catalina Direct about there window seal stuff. Essentially they sell the window gasket that the glass goes into as a kit that runs about $30 and is enough to do all the windows on a C27 and is the "functional" part of the window repair. They also have another kit (about $30) that is the cosmetic insert for the inside of the windows, that makes them look nice but is not "functional" in the sense of keeping leaks out. They also recommended the use of sealant ($14 for a tube that should be enough for all the windows), and acknowledged that a lot of people don't realize that the gasket alone won't do the job. According to the guy I spoke with, if you imagine the gasket as "u" shaped, you need to put sealant on both outside edges/walls of the U gasket, and then also run a bead down the inside bottom of the "u" to seal the glass. Sounds like a plan to me. . . . . I think I will take some masking tape and run strips top to bottom across the window and about 3" each above and below to avoid the flying/falling window problem. There is probably some merit to the idea for my wife and daughter to be elsewhere, but then I wouldn't have my "co-captain/Commodore of the Fleet" and little 18 month old deckhand available to help with the job . . . I'll keep you posted on how it turns out. I will have to say that getting this '76 C27 to restore and enjoy is already becoming an adventure. . . .
