rods
Toni I used the 2 rod system a upper and lower for each window,simply drill pilot holes where each rod is to be mounted, I purchased the rods from the same fabric store., I mounted my rod holder brackets that came with the rods,snapped the rods on the brackets then measured the area to be the curtain, I drew a picture for the seamstrest so she knew what my finnish curtain should look like,the seamstrest then folded the sunbrella approx.1 1/4'' on each end for lap she sewed a lap sleave for the rods to slip into.I had to remember things like do I want the curtains to pleat like the old fabric curtains? allow access for lap for the rods to slip into? be sure to use short screws to mount the rod brackets you don't want to drill thur the body of your boat I put a piece of tape on the drill bit to aleart me to the deapt of the drill bit as I was drilling,If you make a mistake you can use marine tex to patch if necesary. believe me it sounds very simple just replace or make new curtains???? yea right/// it will take a little time and though and effort on your part. as it did for me , but when it's done you will have new curtains that you will like and that will probably out live the boat.I check this forum regularly so if you have questions I will be glad to help you when I can. [mainsailken@aol.com]good luck in the wind jake l.
