Windlass troubles on a 1995 Catalina 320
36
Catalina 320 Dallas
I discovered a my battery was draining on my 320 and after further investigation I discovered it was the windlass connection in the panel. I have disconnected the power lead and all is well. However, I bought the boat used and it has no windlass manual. Does anyone from those 90's 320 have or know where to get the manual so I can troubleshoot the windlass. Thanks
Jan 4, 2006
7,650
Google the brand name and model and you'll get the same manual that came with the unit when new.
Jun 2, 2004
1,077
Several Catalinas C25/C320 USA
Are you turning the windless off after use? You must manually turn it off with the pull/push knob located just below the forward starboard bench seat.
