Will it fit?
12
Hunter 26 Iuka, MS
Looking at buying a new 8hp longshaft 4 stroke Mercury outboard for my 97 H26. Does anyone have this motor on theirs? Does anyone know of any clearance issues with it. Any input would be helpful.
Thanks
Jun 1, 2004
243
Hunter 26 Lake Pueblo Colorado
We have a 9.9 Honda longshaft, with a powerlift and it fits fine. I have noticed while checking out other h26s that there seems to be different motor supports.
-na -NA Anywhere USA
I am known for my knowledge of the 26, 260, 19, 240 and 23.5.
I would suggest the long shaft or 20 inch shaft if you are on an inland lake. If sailing in the oceanl, you may want to consider a 25 inch shaft in following seas. With the 25 inch long shaft, you have to be real careful to tilt it when pulling the boat out of the water on the trailer.
Get one that is electric start and for easy of attachement, use trolling motor plugs for easy disconnect.
TOhatsu also makes Nissan and Mercury small outboards which many do not know that little tidbit.
Crazy Dave Condon
MABell
Dec 9, 2003
232
Hunter 26 Orygun
Mine
The original motor on my ‘98 H26 was an extra long shaft – 25” as Mr. Condon indicates. When I replaced the OB (now 8hp Yahama high thrust) it was the 20” long shaft. It’s OK. I have had a time or two in rough water when the prop surfaced. But, I should have been sailing. Right?
Sep 17, 2011
12
Hunter 26 Iuka, MS
New OB is now in. It fits but does have limited turning radius. I will have to use the rudder for tighter turning ( entering slip ).
Thanks for all the input.
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
I exclusively use my H-26's rudder for steering while under way. I do, however, use both the rudder and outboard tiller for low speed tight steering while backing into my slip. BrianW
Hopefull Rookie;
I am not good at computers and had a fit with trying to respond back which is why I asked you to respond to my personal email. I anser to that and your personal email is protected. Only if you knew who I knew in the past would amaze you as I firmly believe in privacy. davecondon@mindspring.com
Crazy dave
Nov 29, 2004
10
Hunter 260 Lake Hopatcong, NJ
I bought the EZ Steer attachment between the rudder and motor. Turns them together. Makes the boat much more maneuverable.
