Looking to improve my wifi experiences on the boat. Looking for a wireless 12V power-over-Ethernet router. Oh ya. Inexpensive. Suggestions?
I don't get it. Why do you need POE on a wireless router?looking for a router that is POE. Maybe I'm not going to get it....I am going with the bullet but I'm piecing my own system together.
Yep the POE (power over ethernet) is to inject a voltage (12 volts or higher) into the Ethernet cable going to the Bullet radio as it needs power. It has nothing to do with the router. If you get a router like we have you just need to find the appropriate plug for the router and wire it to 12 volts. You could cut the plug/wire off of the 110 volt to 12 volt brick that came with the router and use that.I don't get it. Why do you need POE on a wireless router?
You won't find a cheap wifi router that provides (or runs from) POE.looking for a router that is POE. Maybe I'm not going to get it....I am going with the bullet but I'm piecing my own system together.
The injectors are 'the simple way'. 12 volt hot and ground to it and plug the Ethernet cable from the radio in one side and the Ethernet cable on to the router in the other side and you are done. If you don't want to use one like we did that also raises the voltage you can get the plain Jane ones for under $10 if I remember right. As mentioned you can take the Ethernet cable apart and inject straight into it, but for $10 or less why bother.... You have to power the radio and that can be done with the ethernet cable. But, you have inject power to the right wires somehow. They make injectors but Im looking to simplify... .
Most of all of that is on the link I gave to my site above. I'd still recommend Island Time if most of that doesn't make much sense as you get the right equipment and instructions in one package for not much more than piecing it together.Hey Guys, the above is great for the EE's in the audience, but the rest of us need brands, hook up instructions, sources of gear and recommendations that compare at the dock vs on the hook systems.
Any thoughts?
Just as Sumner says. These vendors have done all the selection and geeky stuff, and their systems can be installed without requiring specialized knowledge.Hey Guys, the above is great for the EE's in the audience, but the rest of us need brands, hook up instructions, sources of gear and recommendations that compare at the dock vs on the hook systems.
Any thoughts?
[/quote]Anytime you can eliminate components, that is simplified.
