P
Patrick
....draining, that is.I'm in the process of winterizing and got all the way to running the pink anti-freeze through the system. It drains fine in the head, but the galley sink just stands there.I've checked the through-hull and it's open and unclogged (as far as I can tell with a screwdriver). It's not exactly clear how the plumbing runs for this sink (which is part of my problem, obviously!). It appears there is a drain hose from the icebox and both run to what looks like a filter device prior to the through-hull. There is also a toggle switch under the front of the sink. Does that control a pump that helps drain it?Thanks for any advice you can give me.Patrick
