Bob
When I board my 1988 Cat. 30 which is almost every weekend now, I first and foremost check the bilge for water. Low and behold it never fails that I have water in the bildge (not oily or malodorous) that just seems to be high enough to not set the pump off (one inch above the bolts). What is interesting is that the windows do not leak nor the hatches. The integrity of the glass in the bilge is perfect and without any minor cracks. I did note that the mounted bilge pump and autofloat (factory) sit high and will not lower the water but an inch from the bottom. I often use a hand pump and bucket to take it down. I am guessing that its possible that my ice in the cooler I leave onboard to melt from weekend to weekend (2-bags) may be the culprit and that I can have a leak somewhere in that drain line or that its somehow coming from the cockpit. I do not believe I have any major leak at least from the thru-hulls. That would be apparent, especially spending time onboard for the weekends.I know this is the $64,000 question, because it opens up a huge number of possibilities, but has any other 30 owner had the same issues or identical problem? Any guesses? remedies? Gee, do I have to running dye tests in my systems? Always appreciate the feedbackThanksBob
