I am considering the purchase of a whisker pole for my 310 with a 135% headsail. I have read on the 320 list that some skippers recommend the 10-18' while others recommend the 12-22'. Also, what method of mast attachment and storage.
Are you stating you do not use your whisker pole? Why?here is my whisker pole attachment.....I am actually thinking about taking it home and storing it there since I never use it :cry:
Stu ..are you saying you raise the outer end of the pole and drop the mast end ?
honestly, because my previous boat did not have one and I never learned how to use it. One of these days I am going to practice using it.......Are you stating you do not use your whisker pole? Why?
Stu Jackson said:LP, just the opposite. If you have the track on the mast, raise the mast end, dip the clew end and bring the clew through the foretriangle to gybe. With the loop of line through the clew, the clew won't "get bent" with the pole through it, nor will the pole come off if only attached to the leeward sheet when it gybes.
